Introduction: Bed Wetter
As the school year goes on and I have to keep getting up early, I find myself accidentally falling asleep after turning off my alarm more and more. To solve this, I created a device that will dump water on me if I'm not out of bed 5 minutes after my alarm goes off.
Required:
- Any Arduino microcontroller (I used a Particle Argon)
- A servo
- A motion sensor
- x Jumper wires
- Some material to build the structure (cardboard, wood, etc.)
- Water bottle (that you will cut a hole into)
- Button
- 220 ohm resistor (or similar)
Step 1: Set Up the Microcontroller
Attach the 3.3V pin to the positive rail, and the ground pin to the ground rail
Step 2: Set Up the Button
Attach the button to the D6 pin and ground
Step 3: Set Up the Servo
Attach the ground to the ground rail, the positive to the 5V a.k.a VUSB pin, and the input to A5
Step 4: Set Up the Motion Sensor
Attach the positive to the 3.3V positive rail, ground to the ground rail, and input to D5
Step 5: Configure and Flash the Code
Flash the following code to your Argon and adjust the config variables accordingly:
int servoPin = A5;
int motionSensor = D5;
int button = D6;
// Config variables. only touch these!!! don't touch anything else
// UTC time zone
int alarmHour = 17;
int alarmMinute = 45;
// in seconds
int delayBeforeSpray = 10;
bool servoStarted = false;
bool disarmed = false;
int servoMin = 10;
int servoMax = 170;
Servo servo;
int alarmUnixTimestamp = 0;
int disarmTime = 0;
void setup() {
recalculateAlarm();
Serial.begin(9600);
servo.attach(servoPin);
pinMode(button, INPUT_PULLUP);
pinMode(motionSensor, INPUT);
Serial.println(alarmUnixTimestamp);
void recalculateAlarm() {
alarmUnixTimestamp = Time.now() + ((alarmHour - Time.hour()) * 60 * 60) + ((alarmMinute - Time.minute()) * 60) - Time.second();
Serial.println("Alarm set to " + Time.format(alarmUnixTimestamp, TIME_FORMAT_DEFAULT));
void disarm() {
disarmed = true;
disarmTime = Time.now();
void rearm() {
disarmed = false;
void open() {
servo.write(servoMax);
void close() {
servo.write(servoMin);
void loop() {
if (Time.now() >= alarmUnixTimestamp + delayBeforeSpray && !disarmed) {
servoStarted = true;
Serial.println("sprayed");
int buttonStatus = digitalRead(button);
if (buttonStatus == LOW && servoStarted && !disarmed) {
disarm();
Serial.println("disarmed (button)");
int motionStatus = digitalRead(motionSensor);
if (motionStatus == HIGH && !servoStarted && !disarmed) {
disarm();
Serial.println("disarmed (motion sensor)");
if (Time.now() >= disarmTime + 30 && disarmed) {
rearm();
alarmMinute += 1;
recalculateAlarm();
Serial.println("rearmed");
Step 6: Attach a Cap to the Servo
Cut out a surface the size of a water bottle cap and attach it to the servo. The surface can be a material of your choice
Step 7: Attach to a Bottle
Attach your motor and a bottle without a cap to a tall surface so that the surface you cut earlier acts as a cap
Step 8: Build the Ramp
Attach a ramp that the water will fall onto
Step 9: Finish the Structure
Add walls to help support the structure. Make sure to cut holes in so that the microcontroller can get power and the motion sensor can see.
