Introduction: Bed - the Jocelyn Model
This plan makes a bead frame for a full size mattress. Although a full size mattress should be standard size. Please make sure you measure yours to see if it will fit before you start building to see if you need to adjust the width or length at all.
All my builds are made with pocket hole joinery. You will need a pocket hole jig tool such as a Kreg Pocket Hole Jig in order to build them.
I have tried to ensure all steps are
covered in these plans but if you find any errors in the plans or have a question then please email me at info@andrewharriswoodwork.com to let me know.
Step 1: Shopping List
Step 2: Cutting List
Step 3: Plywood Cuts
You will need one sheet of 8 feet by 4 feet ¾ inch thick plywood.
Step 4: Make the Foot Board Front Panel
Make the footboard panel using the 1 by 4 pieces shown.
Put pocket holes on the short edges of each of the top and bottom rails as well so that you can fix them to the legs.
Step 5: Attach the Legs
Attach the legs. Inset the front edge of the frame ¾ inch in from the outside edge of the leg.
Step 6: Add the Inner Panel
Add the two ¾ inch plywood panels as the inside panels.
To give the top trim extra strength I used pocket holes on the top edge of this inner plywood panel to screw the top to this inner panel.
Step 7: Add the Back Panel and Footboard Top Trim
I then added another frame the same as the front one over the plywood.
I joined the pieces together first with pocket holes and then nailed the frame to the back of the footboard and filled the nail holes. I then also put more pocket holes on the top edge and screwed the top board to the back frame. This was just to give it more strength.
You can then fill and sand the holes if you want to (but may be hidden by the mattress anyway)
Step 8: Make the Headboard Frame
Make the first part of the headboard using the 48 inch long 3 ½ inch by 3 ½ inch posts and the 1 by 4 pieces shown.
Step 9: Add the Insert Panels to the Headboard
Add the two ¾ inch thick plywood panels measuring 43 ½ by 25 inches as the insert panels.
To give the top trim extra strength I used pocket holes on the top edge of these inner plywood panels to screw the top to this inner panel.
I also put pocket holes on the outer edges of the panels to screw them to the legs.
Step 10: Dd the Top Trim to the Headboard
Add the 1 by 4 piece measuring 59 ½ inches and then the 2 by 6 piece measuring 61 ½ inches as the top trim.
I screwed the 1 by 4 to the frame (as the screws would be hidden) and then attached the 2 by 6 using pocket holes to the plywood insert and then also the back 1 by 4 trim.
Step 11: Add the Back Trim to the Headboard
Add the two pieces of 1 by 4 measuring 51.5 inches long and the 37 inch long piece as the back trim.
Step 12: Side Rails
Make the two side rails out of the 75 ½ inch long pieces of 1 by 10 and the 75 ½ inch long pieces of 2 by 2.
I put the support rail 1 ¼ inches up from the bottom edge but you may want to put higher up depending on whether using box frame or not and depth of mattress.
I used some multi hole metal corner braces to attach the side rails to the footboard and headboard so that they could easily be removed if need to be.
Step 13: Finish
Sand well to smooth our joints and remove any wood glue residue.
Finish each section with stain/paint as desired before fixing the parts together. As I was painting white I also used white sealant to seal any joins.
Step 14: Fix Together and Add Middle Support and Slats
Fix the side rails to the headboard and footboard and then add the center support (2 by 4 piece measuring 75 ½)
Then add the slats. I used some full width ones and some 27 inch ones just to maximize the use of boards and reduce wastage.
