Introduction: Bee Hive
Proto-Green 2022 proyect. Winnie the Pooh group.
🐝July-August🐝
Wooden pallet.
Carafe. (We use an 5l carafe)
Step 1: Get the Wood From the Pallet
🐝Be careful with the screws and the splinters!
Step 2: Sand the Wood
🐝Do this with every plank to make sure that you can't find any splinter.
Step 3: Measure the Wood
🐝Make sure that there are 20 cm on each side to make a have the hive some centimetres above the ground.
Step 4: Cut the Wood
🐝To make the legs of the table, which will have the bee hive!
Step 5: Time to Paint It!
🐝We painted it yellow because of our name of the group "Winnie the Pooh". Also we used blue to combine.
Step 6: Let's Start With the Plastic
🐝First we measure the bottle! We have to cut enough to make the structure.
Step 7: Cut the Bottle
🐝We cutted it first with a cutter to make a hole. After we use the slicer to cut it all.
Step 8: Sand the Plastic
🐝We did it with a cutter, because using a sander it was too complicated. Moreover, with the cutter you can rectify any error you had.
Step 9: Lasser Cut Time!!
🐝We first did the model. We did it with EZCAD.
We did the top of the box, and the parts of the honey bee box.
Step 10: Lasser Cut Time!! Pt.2
🐝 We put our design on the machine and we left it cut the pieces.
Step 11: See If It Fits in the Bottle
🐝If it don't fit,cut more the bottle with a cutter.
Step 12: Build the Top
🐝We put together some of the parts that were made in the cutter lasser, conneting the different parts as it was a puzzle.
Step 13: Start Making the Honey Bee Box
🐝 We made holes in the wood to put some wire to make the "honey bee box" strucure,so bees can build and make honey there.
Step 14: Make Holes in the Bottle for the Bees!!
🐝We make the holes with a drill, so bees can come inside to make the honey. The holes we need to do in both sides.
Step 15: Time to Screw the Structure
🐝We screw the structure to make a kind of table to put into the bottle for the bees.
Step 16: Finished Proyect!
🐝This is how the proyect would looks like when it is finished!
