Introduction: Bee Hive Door
Had some scrape wood laying around that needed to have use. So i built a quick door for my bee hive.
Step 1: Cut, Cut, Cut, and Cut
Used 2 pieces of wood and got all the measurements needed for a good size hole. I had to make a few cuts to go over the waterer. I wanted the trim to look as good as good can be and to cover the length of the hive.
Step 2: Connection & Fitting
So I went back and pre fitted everything before stapling it together. I use a wider bottom piece so that when I put that under the top box of the hive, the outer piece will stop that in place. This way I don't get it pushed back to far into the hive.
Step 3: Put Down & Done
So I finished what I sought out to build and it came out great. Thank you for checking this project of mine out. I really appreciate it.
