Introduction: Beebeecraft Ribbon Jewelry - How to Make Ribbon Pendants
Girls always prefer ribbon jewelry, right? How about DIY silk ribbon pendant to be a necklace just with a piece of chain? Follow me and learn to see how to make this ribbon pendant.
If you are interested in making ribbon crafts, you will like this tutorial. Today we’re going to show you how to make a simple yet very adorable ribbon pendant, hope you’ll like the design!
Step 1: Materials Needed for Making Ribbon Pendant:
Iron Cross Chains Cable Chains
10mm Glass Pearl Beads Strands
Pandahall Elite 4-10mm Iron Jump Rings
4.0cm*0.7mm Silver-color Iron Eyepins
6*12mm Silver Tone Alloy Lobster Claw Clasps
Benecreat 2"(50mm) Wide LightGoldenrodYellow Grosgrain Ribbons
Non Woven Polyester Embroidery Needle Felt for DIY Crafts
Mixed Shape Silver Brass Bead Caps
Benecreat 3.8cm green Grosgrain Ribbons
3.8cm blue Grosgrain Ribbons
Step 2: Make Several Green Ribbon Petals
1st, cut off several square pieces of green ribbon, fold it along the diagonal line;
2nd, fold and again as the pictiue shows;
3rd, glue the ends with glue gun as a petal, repeat the steps to make other more such green ribbon petals.
Step 3: Make Several Other Colors Ribbon Petals
1st, cut off several square pieces of lightyellow and blue ribbon, fold it along the diagonal line;
2nd, fold them and put the bule ribbon inside the lightyellow ribbon like the picture;
3rd, glue the ends with glue gun as a petal.
Step 4: Finish the Ribbon Pendant
1st, cut off a leaf shape strip of green felt, glue the lightyellow ribbon to the felt;
2nd, glue the 2 green ribbon petal aside the lightyellow pattern;
3rd, glue the green ribbon patterns to the hair clip finding together as pictured;
4th, glue a eyepin to the ribbon pattern and add a brass bead cap to the eyepin, make a loop at the end of the eyepin.
Step 5: Finish the Ribbon Pendant Necklace
1st, glue the 10mm glass pearl to the outer ribbon patterns;
2nd, add a chain through the loop of the ribbon pendant, and add a claw lobster to the end and a jump ring to the other end of the chain to connect them.
Step 6: Done!
Hey dear friends, have you fallen in love with the ribbon flower pendant necklace? do you also wanna try it on yourself? Materials are easy to get from Beebeecraft. Just follow the steps, u can make it.
