Introduction: Beebeecraft Tutorial on How to Make Wire Wrapped Earrings With Pearl Beads
Summary: Like wire wrapped earrings? If yes, you can see here and I am going to share you a Pandahall tutorial on how to make wire wrapped earrings with pearl beads.
Do you have your own one pair wire wrapped earrings? And do you plan to try to make one pair for yourself? Then you should see here and an easy earrings tutorial will be shown about how to make wire wrapped earrings with pearl beads. Look at this picture, gather the supplies below and start the crafting then.
Step 1: Materials and Tools Needed for Wire Wrapped Earrings With Pearl Beads:
4mm White Glass Pearl Beads
1.5mm Gold Aluminum Wire
0.5mm Gold Copper Jewelry Wire
Golden Brass Earring Hooks
Golden Jump Rings
Chain Nose PliersSide
Cutting PliersRound Nose Pliers
Step 2: Make the First Part of the Wire Wrapped Pearl Earrings
1st, cut off a piece of 1.5mm gold aluminum wire and twist the wire for three loops, then make a simple contrary loop at the other end;
2nd, cut off another piece of 0.5mm jewelry wire and wrap the wire around the aluminum wire pattern, then slide a 4mm pearl bead onto the jewelry wire;
3rd, wrap the jewelry wire around the aluminum wire in the same way, then continue to add 4mm pearl beads and wrap the wire;
4th, fix the pattern and cut off the extra wire (as shown in the picture).
Step 3: Make the Second Part of the Wire Wrapped Pearl Earrings
1st, cut off a piece of 1.5mm aluminum wire and twist the wire for many loops from different directions (as shown in the picture);
2nd, cut off four pieces of 0.5mm jewelry wire and fix the pattern by wrapping the wire together in different positions;
3rd, wrap another piece of jewelry wire and slide a 4mm pearl bead onto the jewelry wire, then wrap the wire around the aluminum wire;
4th, continue to add pearl beads and wrap the wire until the above wire pattern has been finished (as shown in the picture).
Step 4: Finish the Wire Wrapped Pearl Earrings Making
1st, fix the two wire and pearl patterns by wrapping the jewelry wire;
2nd, add a golden earring hook onto the wire pattern by a jump ring to finish a wire wrapped ring.
Step 5: Make Another Same One Earring
Simple earrings project, do you like them? You can know that we just need to connect the jewelry wire, aluminum wire and pearl beads together, then we will finish the earrings quickly. Now, can you share me your question about the wire wrapped earrings making process? See you!
