Introduction: Beebeecraft Tutorials on How to DIY Spring Flower Ring With Seed Beads
Summary: Do you love handmade flower rings? If yes, maybe you will love today's beaded flower ring. The following beebeecraft tutorial is about how to make a rhombus flower bead ring.
This seed bead flower ring is a good choice for birthday gift, and this Beebeecraft tutorial will show us how to make simple ring with pearl and glass beads, let’s learn how to make them together!
Step 1: Materials Needed for Making a Flower Ring:
2mm seed beads(creamy-white, orange, purple)
0.3mm tiger wire
Glass Pearl Beads Strands
Brass Pad Ring Bases
Step 2: Make the First Flower Petal
1st, prepare tiger tail, slide a seed bead onto a short tiger wire and connect a pearl bead and a seed bead, thread the long wire through the seed bead;
2nd, cross the two wires through the pearl bead and slide 6 seed beads, then tighten the wires;
3rd, add more seed beads in a circle and cross the wire;
4th, continue to add 6 more seed beads onto the wire and cross the wire in the opposite direction;
5th, slide four 2mm seed beads onto the upper wire and cross the wire onto the following seed bead, then cross the two wires as the same steps like above to make 4 more patters to make flower patter.
Step 3: Make the Second Petals With More Seed Beads
1st, prepare another tiger tail, slide 12 seed beads and cross the ends of the tail through the seed bead in a circle;
2nd, slide 15 seed beads onto one of the wires and bend the wire to cross through a seed bead;
3rd, continue to slide seed beads and bend as the above steps to make 3 more
Step 4: Finish the Beaded Flower Pattern
2nd, slide 20 seed beads onto one of the wires and bend the wire to cross through a seed bead;
3rd, continue to slide seed beads and bend as the above steps to make 4 more patterns like the picture;
4th, 3 petals have been finished, tighten the pattern with the patterns above with the tiger wire and the pearl beads in the middle of the 2 patterns as above.
Step 5: Finish This Beaded Ring
Stick the pearl circle to the ring base with a glue gun, A beautiful beaded flower ring comes out!
Step 6: Here Is the Final Look of the Flower Ring With Pearl and Glass Beads:
The free seed bead pattern tutorial has come to the end. DIY a personal seed bead flower ring at home is much fun! And you can also change the color of the beaded ring and it may bring you different feelings, all materials are available on Beebeecraft. Wearing this ring, you will be more charming and catch more attention. Also it is a good choice to make it a gift for your friend. Get down to make the beaded ring, Beebeecraft will never let you down!
