Introduction: Beebeecraft Tutorials on How to Make Pearl Bracelet
Summary: In today’s Beebeecraft tutorial, we are going to learn how to make a bracelet with purple pearl beads and clear glass beads. Get your DIY supplies and start with me now!
Step 1: Materials and Tools Needed:
6mm round purple glass pearl beads
4x4mm faceted bicone glass beads
6x4mm clear pearl luster plated glass beads
0.8mm silver aluminum wire
40x0.7mm golden stainless ball head pins
5x0.7mm silver iron jump rings
12x6mm silver alloy lobster claw clasp
flat nose pliers
round nose pliers
side-cutting pliers
Step 2: Step 1: Make the Purple Pearl Bead Components
1st, use the 0.8mm silver aluminum wire and make a loop. You need a pair of round nose pliers to finish the loop.
2nd, thread a 6mm round purple pearl bead in the silver aluminum wire.
3rd, make a loop at the bottom of the pearl bead. Then wrap the two ends of the bead.
4th, cut the aluminum wire and finish a pearl bead link. Repeat the steps to make more links.
Step 3: Step 2: Make Glass Bead Links
1st, thread a glass bead with a silver ball head pin.
2nd, cut the extra pin, and bend the wire to a loop.
3rd, repeat the same steps to make more glass bead links.
4th, use a silver jump ring to connect five links. Here I use three clear glass beads and two yellow glass beads.
Step 4: Step 3: Finish the Bracelet
1st, connect the glass bead links and the pearl links. You are supposed to use silver jump rings in between.
2nd, make the bracelet as long as you want. Then add two jump rings and a silver lobster clasp to finish your bracelet.
Tip: I also connect the links to my earring settings. Then I make a pair of beaded earrings.
Step 5: Making This Bracelet!
Do you get the tutorial of this jewelry set now? Welcome to find more jewelry making supplies on Beebeecraft!
