Introduction: Beebeecraft Tutorials on How to Make Red Crystal Heart Shape Earrings
Summary: Summer is Coming! Do you want to make a pair of brilliant earrings for summer? Crystal glass beads are the best choice for you because they are shinny! Here I will tell you how to make a pair of red crystal heart shape earrings.
Step 1: Materials and Tools Needed:
10x5mm red heart charm glass beads
6x6mm green faceted crystal glass beads
5mm silver iron jump rings
5cm silver brass head pins
3x4mm silver iron cable chains
18mm silver iron earring hooks
Step 2: Instructions on How to Make the Earrings:
1. Use a 5cm silver head pin to thread a 6x6mm green faceted crystal glass bead. Then you should cut the pin and make a loop. Then repeat this step to make 4 green bead components.
2. Link the silver iron chain to the silver earring hook.
3. You should use a silver jump ring to connect the red heart charm glass bead to the silver chain. Then open the loop and connect the green glass beads to the chain as well.
4. You are supposed to add 5 red heart charm glass beads and 4 green glass beads in total. Then you can repeat and finish the other one.
Step 3: Finish the Earrings
This is an easy earring tutorial for you. You don’t need difficult skills to finish them. All you need is just some beads, chains, earring component and pliers. Find more jewelry making supplies on Beebeecraft and start your craft making life with me!
2 years ago
beautiful! thanks for sharing!
