Introduction: Beebeecraft Tutorials on Making Double Hoop Earrings
Pink is the girl's favorite, and it’s a color full of romantic and sweet. Pearl beads is a common element in jewelry making and is very popular among jewelry lovers. This Beebeecraft tutorial will show you some special tips about how to make a pair of earrings combine the two factors. Pink pearl beads extremely make you shiny and playful. Simple double hoop pink earrings is easy to made. Learn with Beebeecraft, you can create items that actually accord to your personal preference. Once you master the skills for major craft jewelry ideas, you can make them easily at home.
Step 1: Supplies Needed for the Earrings:
Silver Brass Jump Rings
Iron Eye pin
0.4mm silver Copper Beading Wire
4mm Pink Pearl Round Bead Strands 4mm HotPink Pearl Round Bead Strands 11mm MistyRose Acrylic Beads 19mm Silver Brass Earring Hooks Steel DIY Jewelry Plier Sets
Step 2: Make the Basic Part of the Earrings
1st, cut off a piece of eye pin, slide 20 4mm HotPink pearl beads onto the pin;
2nd, twine the eye pin on both ends as shown.
Step 3: Finish the Double Hoop Earrings
1st, cut off a piece of eye pin, slide 10 4mm HotPink pearl beads and Pink pearl beads onto the pin;
2nd, pass the string of pearls through the hoop made at step one, and connect the two ends of the eye pin to make another hoop;
3rd, make a MistyRose Acrylic Beads with eyepins and make simple loops at the ends, then attach them to the beaded hoops before;
4th, add earring hook with a jump ring, and repeat all the steps above to make the other earring to make a pair.
Step 4: Now, This Double Hoop Earrings Have Been Finished:
Wow! How beautiful and sweet the earrings are. These tips are easily to learn and just spend your little time. Fellow the steps above and you can easily have a pair of sweet earrings made by yourself.
