Introduction: Beebeecraft Tutorials on Making Rhinestone Chain Vase
Do you want to own a special and shining vase? So that it can improve the happiness index of life, and make your daily life full of ritual. How about learning to make the vase with Beebeecraft? It’s easy to finish by following this tutorial. Let’s do it.
Step 1: Supplies Needed for the Rhinestone Chain Vase
3.5mm Rhinestone Chains
F-6000 Adhesive Glue
Side-cutting Pliers
Vase
Step 2: Instructions on How to Make the Rhinestone Chain Vase
1st Squeeze the glue around the vase, and then stick the rhinestone chain to the vase.
2nd Cut the remaining rhinestone chain every time after the circle of rhinestone chain is glued.
3th Repeat the above steps to glue the remaining rhinestone chains.
4th Finish the rest of the vase with the rhinestone chain of another color.
Step 3: The Final Look Is Like This:
So far the project of making rhinestone chain vase is completed. It’s so easy, isn’t it? Do you think you can finish it by yourself? I’m sure you can, and be careful when you use the glue. Welcome to find more jewelry supplies on Beebeecraft where you can meet your craft needs.
