Introduction: BeepIt (an Object Finder)
Hi look at what we are going to do. A connected objet finder like a keyholder. We'll locate the object with a sound who's activated whith an android app i done. This app used Bluetooth.
Step 1: The Items Listing
We must do a few things and list item to use.
So we need: (links are present only to inform you. Buy where you want :))
- Arduino Uno Card
- Attiny45
- Hc05 Bluetooth
Lithium batteries (Pay attention // I use batteries like this but maybe a button cell is cool too.)
Wires
soldering iron
battery recharge (if you need or want)
Step 2: What We Are Going to Do
The app called BeepIt speak with a bluetooth module who was connected on an arduino.
The arduino is too big and the code in it will be added in a AtTiny45 Microcontroller.
- 1 - We prepare the Arduino to speak with the attiny45 :
Read this link that works for me. http://highlowtech.org/?p=1695
After that :
Connect the Arduino Uno board to the USB port of your computer
Launch the Arduino program * Go (tools / serial port) select the COM port on which is connected to the Arduino board.
Go to (File / example) and click (ArduinoISP)
Go (Tools / Card Type) click (Arduino Uno)
Go to (File) click Upload
The Arduino is now able to program a ATtiny
Unplug the USB connector and make the small assembly.. (Picture Named : P1)
- 2 - Chose the Attiny45 in arduino IDE :
Reconnect the USB jack
Go (Tools / Card Type) click (Attiny and go another time to tools and chose processor 45 internal 8 MHz clock)
Go back into (Tools / programmer) click (Arduino as ISP) to indicate to the IDE that the UNO is used as a processor.
Go to (Tools) and click (Burn the boot sequence)
Go to (File) click Upload or icon * At the bottom of the window displays the following message Do not hold actually account if this message is that everything went well
- 3 - Program the Attiny45 in arduino IDE :
copy paste the code between ::::::::::::::::::::::::::
#include SoftwareSerial serieBT(0, 1); // on dit que l'on utilise les pins 10 et 11 à la place des pins 0 et 1 de la carte arduino
char val;
int buzzer = 2;// Borne de sortie buzzer connectée sur le attiny 85
void setup() {
//Serial.begin(9600);
serieBT.begin(9600);
pinMode(buzzer,OUTPUT); }
void loop() {
if (serieBT.available()) {
val = serieBT.read();
Serial.print(val); // on ecrit la valeur
switch (val) {
case '3' : digitalWrite(buzzer, HIGH);
delay(500);
digitalWrite(buzzer, LOW);
delay(500);
delay(500);
delay(500);
delay(500);
break;
- 4 - Now the code is in the Attiny45
We have to test our assembly (watch picture named : P2 )
In our code the Bluetooth RX TX are connected on the Attiny45 pin 0 et 1 and the buzzer on the pin 2.
Step 3: The Application
Next we must test the application and you have to upload it on your phone.
Download the app
Here the new link : https://drive.google.com/open?id=0B78-qX8DXDMsNUcz...
and the
Ai file https://drive.google.com/open?id=0B78-qX8DXDMsTlhs...
if you want change things on it (the file works on this plateform http://ai2.appinventor.mit.edu/
The application is free and you cant find it on Playstore for now so you have to download It.
But as you already know it the code to hear the speaker is 3. So if you got and bluetooth sender/app and that you send 3 to the bluetooth module it'll respond.
Step 4: What Else ?
Know you just have fix all this thing together. Watch the pictures to have an idea on my assembly.
I made a case with a laser cutter and test on with a 3d printer.
I hope this is done and that works for you.
If you use my app and create this "tracker" please let me know it. I'll be proud about it.
Thanks and vote for me ^^
