Introduction: Beginner Friendly: What's for Dinner Arduino Project. Includes Code
Are you tired of deciding what to have for dinner every night? Let your Arduino take care of it with this fun and interactive "What's for Dinner?" project! This project uses an Arduino Uno, a 16x2 LCD display, a push button, and a potentiometer to randomly suggest a dinner option from a predefined list. When you press the button, the Arduino will display a random dinner choice on the LCD screen, making meal planning both simple and enjoyable.
Arduino Uno board
16x2 LCD Display (with a parallel interface)
Push Button
Potentiometer (10k Ohm)
Breadboard
Jumper Wires
220 Ω resistor
10K Ω resistor
Step 1: Copy the Fritzing Diagram
Use this to set up, detailed instructions below too.
Step 2: Connect Arduino and Breadboard
- connect from 5V to positive ground rail
- connect from GND to negative ground rail
Step 3: Add LCD Screen
- VDD: Connect to positive rail
- GND (VSS): Connect to negative rail
- VO: Connect to the middle pin of a potentiometer. Connect one end of the potentiometer to 5V and the other end to GND.
- RS: Connect to Arduino digital pin 12.
- RW: Connect to negative rail (since we are only writing to the LCD).
- E: Connect to Arduino digital pin 11.
- D4-D7: Connect to Arduino digital pins 5, 4, 3, and 2 respectively.
- A (Anode): Connect through a 220 Ω resistor to positive rail
- K (Cathode or GND): Connect directly to negative rail.
Step 4: Add Potentiometer
Connect V0 to the middle pin of a potentiometer. Connect one end of the potentiometer to positive ground rail and the other end to negative ground rail.
Step 5: Add Button
- Connect one leg to Arduino digital pin 7.
- Connect the other leg to GND through a 10k Ohm resistor.
Step 6: Copy Paste Code in Arduino IDE
Step 7: Connect Laptop and Arduino With USB Cable
Step 8: Run the Code
Finished!
