Introduction: Beginner's Guide to Crochet
this tutorial is for anyone wanting to learn how to crochet.
medium weight yarn and 5.5mm crochet hook
Step 1: How to Start a Chain
first you want to make a slipknot (use the pictures for reference) then insert your hook into the slipknot, to make a chain stitch you need to put the yarn over the hook and pull through the center, repeat until you get to 13 stitches.
Step 2:
metric hook sizes US hook sizes UK hook sizes
2.00mm B/1
2.25mm C/2
2.50mm D/3
2.75mm E/4
3.00mm F/5
3.25mm G/6
3.50mm H/8
3.75mm I/9
4.00mm J/10
4.25mm
4.50mm
4.75mm
5.00mm
5.50mm
6.00mm
6.50mm
7.00mm
8.00mm
9.00mm
10.00mm
Step 3: How to Correctly Hold the Hook and Yarn
to correctly hold the yarn you must hang it over your index finger then lead the tail end behind your hand and between your ring finger and pinky finger. to properly hold the hook hold the main part of the hook between your thumb and index finger (use the pictures for reference).
Step 4: How to Single Crochet
start with a chain of 13 stitches insert the hook through the second chain from hook, yarn over hook and pull through, yarn over hook one more time and pull through, repeat 11 more times.
Step 5: How to Half Double Crochet
start with a chain of 13 stitches, yarn over hook insert in the third chain from hook, yarn over hook and pull through, you should have 3 loops on your hook yarn over hook and pull through all 3 loops, repeat until you reach the end.
Step 6: How to Double Crochet
start with a chain of 13 stitches, yarn over hook and insert though the third chain from hook yarn over hook and pull through you should have three loops on your hook only pull through the first 2 loops, yarn over hook one more time and pull through, repeat till you reach the end.
Step 7: How to Treble Crochet
start with a chain of 13 stitches, yarn over hook twice and insert though the third chain from hook yarn over hook and pull through there should be 4 loops on your hook, yarn over and pull through the first 2 loops, yarn over hook and pull through the next 2 loops, yarn over hook and pull through the last 2 loops, repeat untill you reach the end.
Step 8: How to Make a Magic Ring
chain 2, in the second chain from hook single crochet 6 pull the tail end until the hole in the center closes.
I hope this helps you learn how to crochet!
