Best Show & Tell Backpack Ever
Intro: Best Show & Tell Backpack Ever
About 3 days ago I got an assignment for a show and tell. The idea is to find or make an item that you will be taking to mars (only one item ) so decided to make a backpack with everything I want in it. The backpack will be containing the following:
cubesat
coms and antennas
solar panels
ground support equipment
power systems
mini laptop
BT-speaker
Sample container
controll systems
gun
STEP 1: Cubesat
you'll need :
10x5x5 box
Two 5x5 circuit boards
wires
scarp metal
antenna
Take the 10x5x5 box and cut a square into the lid
cut small squares into the sides for the 2 small solar panels glue them in place
close lid and place a metal square on the bottom and gloe the antenna to it
STEP 2: Coms and Antennas
you'll need:
tedelex transceiver
Tape measure strips 30 & 40 cm long
wood strip 67cm long
screws
12 volt battery
skrew the tape measure strips to the wood strip it should look like a T with two horizontal lines
connect a wire to the strips and then to the resciver
connect the reciver to the battery
STEP 3: G.S.E (AKA: Tool Kit)
you'll need
tool case
gas soldering iron
volt meter
screwdrivers
pliers
place all tools in case ;)
STEP 4: Power System
you'll need
12 volt battery
12v socket
wires
connect the socket to the battery
STEP 5: Mini Laptop/ Controll Systems
note* I did not have cash to buy a raspberry for my control system so used a broken tablet and a working controller
you'll need
tablet or raspberry screen
keyboard
controller
STEP 6: Attach Everything
This is the best part according to me LOL!!!
Now you just have to attach the antenna, socket, transceiver, and BT-speaker oh and the tablet
I used zip ties to ties to attach the antenna, speaker and the socket to the backpack
the toolkit, cubesat, gun, battery, controller and box are just placed inside the backpack.
Penolopy Bulnick 4 years ago
