Introduction: Bi Polar Stepper Motor With L293D and Arduino
Hi,
I had a Bi Polar stepper motor lying, which I'll be using to create a Dolly for my DSLR.
Components used:
- Arduino Uno
- Stepper Motor ML17A3 B (This is the model no printed on motor)
- Breadboard
- L293D
- 9v Battery Pack
- Some Jumper cables
To make the connections, follow the circuit diagram.
Step 1: Connections on Breadboard
The images show the step by step connections made on bread board. I started off with GND pins and then to the motor and then Arduino and finally the Battery Pack.
Step 2: Code
I used the code from Arduino IDE. I tried with stepper_OneRevolution and stepper_OneStepAtATime example and they worked fine. The code is listed below.
This program drives a unipolar or bipolar stepper motor. The motor is attached to digital pins 8 - 11 of the Arduino. The motor should revolve one revolution in one direction, then one revolution in the other direction. Created 11 Mar. 2007 Modified 30 Nov. 2009 by Tom Igoe */
#include
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution // for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8,9,10,11);
void setup() {
// set the speed at 60 rpm:
myStepper.setSpeed(60);
// initialize the serial port:
Serial.begin(9600); }
void loop() {
// step one revolution in one direction:
Serial.println("clockwise");
myStepper.step(stepsPerRevolution);
delay(500);
// step one revolution in the other direction:
Serial.println("counterclockwise");
myStepper.step(-stepsPerRevolution);
delay(500); }
Step 3: Final Testing
The testing video.
