BichoBot, 3D Prited BeetleBot Robot
Intro: BichoBot, 3D Prited BeetleBot Robot
STEP 1: Electronics
The operation is very simple, as you can see in the electrical connection of the previous image, when you press the corresponding limit switch, you can change the direction of rotation of each motor. This way when, for example, if BichoBot collides with the left antenna (right side), the left motor rotates back and the right continues to rotate forward, getting the robot to turn on itself and change its path.
Material list:
2x 1,5V dc motor
2x Limit switch No-Nc
2x AAA
1x AAA battery holder
10x 2x10mm screws
Wire an tin.
STEP 2: Post-printing
To improve the slip of BichoBot, I recommend putting heat shrink around the "feet" and a piece of felt in the back as seen in the image.
For more fun, you can print several diameters of "feet" and go testing, with larger diameters get a higher speed and if you swap between feet, you can get circular trajectories.
STEP 3: Print Settings
For the 3d impression of the lower support, the antennas, the "feet" and the support of the motors, it is not necessary to print with quality, to activate supports or to put raft. However for the case, I recommend defining supports in Zigzag to 5% minimum and a 6mm raft to ensure a good impression.
3 Comments
robomaniac 3 years ago
Swansong 7 years ago
This is cute :) I like how you used the antennae to provide a buffer.
brico3d 7 years ago
jajaja thank you very much!!
