Introduction: Make Your Bicycle Sound Like a Motor Cycle - Turbo Spoke - Twin Version
A simple DIY project
Step 1: The Initial Setup
an L angle was welded to the bicycle.
measurements given are indicative. pl improvise according to your need for the bicycle dimensions
Step 2: The Resonance Duct and Amplifier
I took a 32 mm pvc L angle coupler and took two small pieces of 32 mm pvc tube. refer measurements in the photo given. drilled three holes in the smaller one. one hole at the base and two through and through for securing the Rattler
Step 3: Positioning and Fittment of the Resonance Duct
Step 4: Making of the Rattler
I used an old pvc dusting powder bottle for the white plastic strips.
Step 5: Fittment of the Rattler to the Duct
Step 6: The Twin Version
I used a hinge to eliminate the welding work.
I hope the images will be sufficient enough to explain how to do it. of course sky is the limit for improvisation of this pesky noise maker. kindly share your improvisations .
