Introduction: How to Make a Bidirectional Counter (FSM)
A counter is a digital circuit that is used for counting input events (pulses, edges). Digital electronic counters are usually built from a series of flip-flops connected in cascade.
This Instructable is intended to show how to build bidirectional counters (FSM) having different interface methods designed in GreenPAK. The methods to be implemented are:
- 16-bit FSM with SPI output
- 16-bit FSM with I2C output
- FSM with parallel outputs (based on glue logic)
Below we described steps needed to understand how the solution has been programmed to create a bidirectional counter. However, if you just want to get the result of programming, download GreenPAK Designer software to view the already completed GreenPAK Design File. Plug the GreenPAK Development Kit to your computer and hit the program to create the amplifier.
Step 1: 16-bit FSM With SPI Output
The “16-bit FSM with SPI output” counts input clocks in an internal 16-bit register (FSM0, FSM1), at any time a user can read the value via SPI, reset the 16-bit register, or change the direction of counting. The design is implemented in SLG46140, or SLG46620 as well.
Let’s see how it works. The 16-bit counter is implemented using two counters (FSM0 and FSM1 blocks) with additional logic, since SLG46140 doesn’t have 16-bit FSM. Bits 15 – 8 are stored in FSM0, Bits 7 – 0 in FSM1. Both FSMs are connected to the SPI block, which can output serial data via SPI. The direction of counting is controlled by Up/Down pin. If this pin is HIGH, the system counts UP, if this pin is LOW, the system counts DOWN. Gen Reset pin is used to reset counter value (active HIGH).
Input clocks come from Clock input. These clocks are applied simultaneously at CLK inputs of FSM1 and FSM0. FSM1 counts each clock, whereas FSM0 counts only when FSM1 counter value is 255 and Up/Down signal is HIGH or when FSM1 counter value is 0 and Up/Down signal is LOW. This functionality is achieved using KEEP input of the FSM0. When this signal is HIGH the counter value of the FSM0 is not changing despite the clock signal. The KEEP input is connected to FSM1 output through an inverter. FSM1 output in turn is HIGH only when counter value is 0 and Up/Down signal is LOW, or when the counter value is 255 and Up/Down signal is HIGH.
Since the FSM counter value is reset to counter data when the FSM counter value reaches the maximum (255) and FSM1 counter data is 255, FSM1 stops at a max value (255) when counting up and FSM1 UP input signal is HIGH. In order to avoid this situation, DFF2 and 3-bit LUT1 reset FSM1 by the next clock when FSM1 reaches max value and Up/Down is HIGH. If Up/Down is LOW, FSM1 is not reset. The situation is similar with FSM0. This one is also reset to counter data, and when FSM0 reaches max value (16383) it will then start to cause incorrect data. In order to avoid that situation, 3-bit LUT3 resets FSM0 by the next clock when both FSMs reach max value (SPI output code in this situation is 0xFFFF) and Up/Down is HIGH. Both FSMs are not reset if Up/Down is LOW.
D0 – PIN#6 (nCSB)
D1 – PIN#7 (SCLK)
D2 – PIN#12 (MISO)
D3 – PIN#2 (Gen Reset)
D4 – PIN#3 (Up/Down)
D5 – PIN#4 (Clock)
The following design, which is shown on Figure 3, is just a modification of the 16-bit FSM with SPI output. This design can be used if we need to detect an overflow (OVF) event and set the initial value of the 16-bit counter (FSM0 and FSM1).
The initial value of the 16-bit counter is set to ½ maximum value (FSM0 data = 0x7F, FSM1 data = 0xFF) and can be adjusted easily. The initial value setting process takes ~9ms and starts just after the power-up of GreenPAK IC, or when High pulse is applied to “Gen Reset” input. During those, ~9ms FSM0 and FSM1 receive pulses from the internal OSC and will ignore pulses from Clock input. The initial value depends on CNT0 counter data and Pipe delay “OUT0 PD num” value. CNT0 counts the clock from the internal oscillator simultaneously with 16-bit counter. Pipe Delay in turn counts output pulses from CNT0. When Pipe Delay OUT0 goes HIGH, the OSC is stopped by this signal (2-L5) and clock signal for 16-bit counter is taken from Clock input. To change the source of clocks, a 3-bit LUT0 is used. Also, when Pipe delay OUT0 is LOW, it forces the 16-bit counter to count DOWN, in order to guarantee the correct direction of counting during the initial value’s set process. The initial value is determined by the following formula:
𝐼𝑛𝑡𝑖𝑎𝑙 𝑣𝑎𝑙𝑢𝑒 = 65535 −((𝐶𝑁𝑇0 𝐶𝑜𝑢𝑛𝑡𝑒𝑟 𝑑𝑎𝑡𝑎 +1) ∗ 𝑃𝑖𝑝𝑒 𝐷𝑒𝑙𝑎𝑦 𝑂𝑈𝑇0 𝑣𝑎𝑙𝑢𝑒 − 1)
In the case of 16-bit counter overflow, an according to OVF output will be set and latched. It will be reset after IC reset or when “Gen Reset” or “OVF Reset” signal comes. This function is implemented using the following components: DCMP0, DCMP1, 4-bit LUT0, 2-L4, and DFF2.
In Figure 3:
D0 – PIN#6 (nCSB)
D1 – PIN#7 (SCLK)
D2 – PIN#12 (MISO)
D3 – PIN#5 (OVF Reset)
D4 – PIN#2 (Gen Reset)
D5 – PIN#3 (Up/Down)
D6 – PIN#4 (Clock)
D7 – PIN#11 (OVF)
The last design which is related to 16-bit FSM with SPI output is “16-bit FSM with SPI output, zero detector and initial value's setting function”.
When the 16-bit counter value is equal to zero, a corresponding ZD output (Zero detector) will be set and latched. It will be reset after IC reset or when “Gen Reset” or “ZD Reset” signal arrives.
Step 2: 16-bit FSM With I2C Output
This design counts input clocks in an internal 16-bit register (FSM0). At any time the user can read the value via I2C, reset the 16-bit register, or change the direction of counting. This design is implemented on SLG46533. There is one more FSM cell that can be used to get one 32-bit register or two independent 16-bit registers. Also, the initial value can be set in the same way as in previous designs.
The DFF3 and 3-bit LUT1 have the same purpose as in “16-bit FSM with SPI output”, namely reset FSM0 by next clock when FSM0 reaches a max value (0xFFFF) and Up/Down signal is HIGH, since FSM0 stops when it reaches max value and FSM0 UP input is HIGH.
D0 – PIN#3 (Clock)
D1 – PIN#4 (Reset)
D2 – PIN#5 (Up/Down)
D3 – PIN#8 (SCL)
D4 – PIN#9 (SDA)
Step 3: 9-bit FSM With Parallel Outputs
The last design is a bidirectional counter with parallel outputs. In order to build this bidirectional counter, connected DFF in series is not enough. For building the bidirectional counter additional logic components are needed. The design is built based on DFFs and LUTs. At any time the user can reset the counter value or change direction of counting. Keep signal (active HIGH) is designated to keep counter value regardless clock signal.
D0 – PIN#3 (Up/Down)
D1 – PIN#4 (Keep)
D2 – PIN#5 (Clock)
D3 – PIN#7 (nReset)
D4 – PIN#15 (Q3)
D5 – PIN#14 (Q2)
D6 – PIN#13 (Q1)
D7 – PIN#12 (Q0)
In order to increase the number of outputs, “One-bit” section (3-bit LUT2, 2-L1, DFF6) should be just copied, as is shown in Figure 14.
Conclusions
Counters have become an integral part of most devices such as real-time systems, speedometers, odometers, electricity meters, counting revolutions, etc. GreenPAK is ideal for implementing the required counter function with lower cost and small board space.
