Introduction: Big Ben :D
About: I Love Tinkercad and creating awesome things!
This instructable explains how to make your very own Big Ben :)
All you need is Tinkercad and a little bit of time, So let's get started
Step 1: Make the Tower
To Make the tower, First size a square's width and length to 34 and its height to 32 and take another square, size the length to 2 and the width to 2 then, make it 32.00 tall, then duplicate and space them apart on all four sides of the first square, change four on the corners to holes and then group them
Step 2: Assemble the Tower
Size the height to 160 on the thing we made in the last step
Step 3: Make the Clock Face
To make the clock face use a cylinder and size it to 23.00 by 23.00 then color it white and rotate it 90 degrees.
Use a box and make it 34.00 by 34.00 and make the height 32.00 and then make another box 2.00 by 2.00 and make the height 32.00. Then duplicate it 3 times and put it on the corners of the big square. Now make another square and size the length to 24.59 and the width to 4.59, then put the height at 24.13 then use the cone and put it up to 8.00 then put it on all four sides. Then group them all together
I imported a clock face SVG for the actual clock number and then size it to the same measurements as the cylinder and align them and put them on all sides of the shape we made above.
Step 4: Make the Tower
To Make the Tower size a pyramid to 34.00, 34.00 and make the height 28.33, then make a square into a hole and raise it to 4.00 and then group it. Now, duplicate it and size the length to 29.25 and the width to 29.00, and then make the height 18.20.
For the next part, make a square 20.40 by 20.40 and make the height 2.22, now make a cylinder to 1.94 by 1.94 and make the height 11.14 then duplicate 3 times and space them apart. Then make the length of a square to 16.03 and the width to 2.91 and then make the height 1.31 and raise it on top of the cylinders then duplicate the on all four sides of the first square.
To make the top of the tower, duplicate what we did in the first step and size the bottom pyramid to 18.70 by 18.70, and delete the top duplicate and instead use a pyramid and make it 15.63 by 15.70 and make the height 30.95 and then make a square and raise it to 20.00 then group and put a pyramid on top and then assemble ALL of this step and it should look close to the first picture.
Step 5: Assembleage!
Now it's time to put them all together!
