Introduction: Big Pencil
Problem: The current pencils on the market are too small for people with larger hands. This creates discomfort and difficulty when using a standard pencil for an extended period of time, which can lead to decreased productivity and frustration.
Constraint List:
-The larger pencils should be lightweight and easy to hold.
-The pencils should be durable and long-lasting.
I conducted research to understand the needs of individuals with larger hands and the current market offerings. We found that there is a lack of options for larger pencils, and many individuals experience discomfort and fatigue when using standard-sized pencils.
Brainstorming Ideas:
Based on my research, I came up with several ideas for creating larger pencils that meet the constraints listed above:
  1. Create a pencil with a wider barrel diameter to accommodate larger hands.
  2. Use lightweight materials such as bamboo or recycled plastic to create a larger pencil that is still comfortable to use.
  3. Develop a range of ergonomic grips that can be attached to standard pencils to make them more comfortable for individuals with larger hands.
  4. Create a set of jumbo-sized colored pencils that are easy to grip and use.
In summary, I have identified a need for larger pencils for people with larger hands and have developed a solution to meet this need. Our solution involves creating a pencil with a wider barrel diameter using lightweight materials. By following the Engineering Design Process and taking into consideration the constraints and needs of our target audience, we have created a viable solution that can be used to improve the writing experience for individuals with larger hands.
you will need several materials wood slats, a saw, a drill, yellow and red marker, and glue. Make sure you have all the necessary materials before beginning the process.
Step 1: Gather Materials
To make a pencil, you will need several materials wood slats, a saw, a drill, a sander, a black crayon, and glue. Make sure you have all the necessary materials before beginning the process.
Step 2: Cut and Shape the Wood
Using a saw, cut the wooden slats into pencil-sized lengths. Then, using the sander, shape the wood into a hexagonal shape to prevent the pencil from rolling off a desk.
Step 3: Drill a Hole in the Center of the Wood
Using a drill, create a small hole in the center of the hexagonal wooden slat. This is where the crayon wax will go in. You melt the crayons until it looks good enough to sharpen like a pencil lead.
Step 4: Paint the Pencil
use a yellow marker and color in the middle part of the pencil and at the end of the pencil color it red to make it look like an eraser.
