Introduction: Bike Box
In this instruct able I will show you how I made a box that I can do tricks on and off out of OSB and some 2x2 posts.
Step 1: Prep and Cutting Wood
First get the tools you will need ( circular saw and something to cut the wood on.) I wore sunglasses as eye protection but any other eye protection will do.
I wanted to make my box 16 inches tall, 2 feet wide and 6 feet long.
Next I cut enough wood from the posts to make two boxes or frames - one for each end.
Step 2: Make the Frames for Each End
For the frames I hammered a two foot piece of wood onto two 1 foot pieces at a 90 degree angle.
next I added a piece between the two bottom posts to hold it all together.
Step 3: The Plywood
I then cut a piece of OSB which was two feet by six feet and fastened it onto the frames.
I then added two pieces of wood post in the middle of the OSB at a 90 degree angle towards the ground and then fastened them in place.
Step 4: Finishing
I then added two slabs of 6 foot long by 16 inches tall OSB into the side and fastened them with nails.
Now you can grab your bike and have some fun.
It you are a BMX rider you can also wax the corners or edges to make them good for grinding!
