Introduction: Bike Chain Fidget Ring
Usually This Fidget Chain Ring is 30$, maybe 10$ on sale. But now you can make it practically free!
+ you don't need a 3d printer like many other DIY fidgets!
Here are the Materials You Will Need
-6 Links of Old Bike Chain
-A Bike Chain Tool, or a mallet and a small screw driver
-6 Orthodontic Rubber Bands(like the braces ones), or a small tire of some kind
-And Maybe Some Pliers
There's only 4 things needed! Keep in mind, this project should take about 30 minutes.
Step 1: Taking the Chain Apart
This is by far the hardest step.
1st Separate out 6 Chain Links
Then disassemble every chain link using the bike chain tool. The first picture above shows all the pieces you should have when your done.
*if you are using a mallet and a screw driver gently pound the pin until the chain separates.
Step 2: Wash Your Chain Links
This the easiest step! Yay!
Find a small container that can get dirty.
Then wash all your chain links in a dish soap and water mixture.
Shake the container for a minute and let the links dry on a dish towel.
MAKE SURE YOU DONT LOSE ANY LINKS!
Step 3: Adding the Rubber Bands
Slide the 6 Rubber Bands over all 6 Metal rings, 1 band on each.
Your Almost DONE :]
Step 4: Reassembly
This is the last step but it is also one of the hardest.
Reassemble your chain links using the bike tool.
MAKE SURE THE LOGO FACES AWAY FROM THE LINK!!
Made that mistake more than once, and you have to take it all apart and then reassemble is again. :(
A rubber mallet might help if the pin doesn't go through the link all the way.
After You have assembled the fidget use some pliers to loosen the links.
Step 5: And Your Done :) YAY
Now enjoy fidgeting in the classroom or in the office.
No matter what you do, Have Fun!
