Introduction: Bike Flashlight Mount With Angle Adjustment
clamps to handlebar. can hold most flashlights . can quickly reposition with one hand the angle of light while riding . has 15cm rise above handlebar to get light closer to eye level for less shadowing effect
light weight softwood
strong hardwood for bottom clamping piece
m8 wingnuts ordered from online , has 7 threads that wont strip compared to 3 threads from generic ones
m8 bolts 90mm
m4 or m5 bolts for clamping to flashlight
1mm stainless sheet
silicone rubber sheet 1mm for grip
a 2 x 21700 flashlight
Step 1:
cut hole in softwood with 30 or 32mm hole-saw
use a mitre saw to cut through the hole you just drilled , cut off 1/3
file down this part so it can fit on your handlebar
use 7 or 7.5mm drill bit to install bolts into softwood , lubricate holes with beeswax finish
cut heads off bolts after installing
file down bolts so wingnuts can screw on
install a hose clamp or similar on your handlebar to stop unit from sliding sideways
when finished tighten down the wingnuts hard , grip it from the top and push or pull to adjust angle
