Introduction: Bike LED Turn Signals
I was re-published on TreeHugger!!! http://www.treehugger.com/slideshows/gadgets/how-make-led-turn-signals-your-bike/
Turns out the guys at CleanTechnica and WonderHowTo blogged about this without telling me first. Not sure if I should be upset or happy, haha. Check it out:
http://cleantechnica.com/2012/10/17/led-turn-signals-for-your-bike-by-a-9th-grader/
http://cycling-lessons.wonderhowto.com/how-to/add-led-turn-signals-your-bike-for-safe-road-cycling-0138678/
I made a schematic using Upverter! This should help a lot of people.
Update 8-5-12: Thanks so much guys for the homepage feature AND the newsletter feature! I've always wanted one of my instructables in the newsletter!
Hand bike signals are boring, and who doesn't love electronics and LEDs? I don't do much road biking where I actually need turn signals, but they look cool and are fun to make. Also, they go great with an Altoids Bike Headlight on the Cheap! (That's another one of my 'ibles.)
~~~If you like this, please please please vote for it in the Bicycle, LED, and Hurricane Lasers Contests!~~~
**Video of the turn signals in action coming soon!**
Step 1: Ingredients
- 1- Project Box 3x2x1. UPDATE: scratch this. Use a bigger one! The pins from the switch didn't fit inside so I had to mount it the wrong way, and the battery didn't even fit! I would suggest using one at least a 1/2 inch bigger on all sides.
- 3- Velcro Straps or Hose Clamps - you could use zip ties, but then you would have to cut them every time you needed to remove the turn signal system for transportation.
- 1- Project Box 5x2.5x2
- 2- 10 ohm resistors
- 1- 9V battery snap
- 1- Center Off 3-way toggle switch
- 10- 5mm Yellow Flashing LEDs. Get some that require 1.8V so that you can use a 9V battery.
- 10- 5mm LED holders
- 2- old bike reflector mounts (one rear mount and one front mount)
- 1- 9V battery
- Hot glue or super glue
- Screws
- Drill with assorted bits
- Solder & Soldering iron
- Screwdriver
Step 2: Reflector Mounts
First, you need to disassemble the reflectors to get the mounts. All reflectors are different, so you're on your own for this step. For mine, I just needed to bend back a little piece and it popped right off. I also needed to sort of combine two mounts to make a rear mount that would work. Now mount one on the front and one on the back like shown in the pics.
Step 3: Switch-box
Now we need to make a switch box. This will house the toggle switch and battery. First, we need to decide how we want to mount it on the bike. I will mount it beside the left handlebar and use a screw to attach it to the reflector mount. Now drill a hole for the toggle switch to fit in wherever you want. The box is really easy to drill through, so be super careful! Mount the switch to make sure it fits, then remove it so you can wire it up. Wire the middle pin of the switch directly to the positive lead of the battery snap. On both of the other pins, solder a 10 ohm resistor. Then solder a wire to each of those resistors that can reach the rear reflector mount with about 6" of extra wire for safety. Use heat shrink if necesary. Now solder two wires of that same length to the ground wire of the battery snap. Drill a small hole in the bottom of the box and feed the wires through it. Re-mount the toggle switch, secure the 9V battery in the box, and close it. My battery didn't fit in the box because of where I placed the toggle switch, so I had to use a dremel and cut a slot for it to stick out through. I covered the protruding end with electrical tape. Don't mount it on the reflector mount yet.
Step 4: Wiring & Mounting the LEDs
Using a nail or other sharp object, make 10 dots on the larger project box in the shape of left and right arrows (5 LEDs per arrow). Be sue they are spaced apart enough so that the LED holders won't touch. Drill the holes and place LED holders and LEDs in. Turn the LEDs so that all the positive leads are facing the same way and the negative leads are facing the same way. If needed, use hot glue or super glue to secure the LEDs in. Bend all the + leads of the LEDs. Connect all the positive leads of the LEDs of one arrow with wire. Leave a little peice of wire sticking out of the bottom LED. Repeat for the next arrow. Now use this same method to connect all the negative leads of one arrow, and then the other. Solder them to ensure a good connection. Now you need to drill a small hole in the side of the box opposite your LEDs and feed the wires coming from the switch box into the hole. On the bottom LED of each arrow, attach one of the wires from the switch to the positive lead. Also solder a wire from the ground wire of the battery lead to the negative lead of the same LED. Once everything is connected, test it out to make sure it works and then close the project box. If it doesnt work, make sure all the connections are solid and that none of the leads are touching if they dont need to touch. Mount it on the reflector mount using any method you want (glue, screws, etc.). If you're using a drill, be sure you don't drill into any components in the box.
Step 5: Mounting It on the Bike
Mount the switch box so that when you flip the toggle switch up, it turns on the right arrow and when you flip it down, it turns on the left arrow. This is how the turn signals work on a car. If you don't want to do that, you could mount it so that flipping it left turns on the left arrow and flipping it right turns on the right arrow.
Now mount the LED box on the back.
Step 6: Securing Wires
Use zip ties or velcro straps to secure the wires along the frame of the bike. Be sure to leave enough slack at the front so that the wires don't hinder your ability to turn. If you still have some slack, push it into the larger project box (there's plenty of room in there).
Step 7: Go Riding!
Now go riding on the road and show everyone your new and awesome bike turn signals. You may even get some requests from some friends to install some on their bike! Be sure to charge them a good amount, though!
If you have any questions, feel free to ask! I'll be happy to answer any questions.
Thanks for looking!
Step 8: Hurricane Laser Cutter
Now, since this is in the Hurrican Laser Cutter Contest, I need to tell you what I would do with one of their amazingly cool and awesome and robotic laser cutters.
First of all, I like to do papercraft. Now I am using a hobby knife to cut all the pieces out, which makes it look terrible and is very time-consuming.
I also like to do some woodworking, and this would allow me to make precise cuts on my projects.
Third, my dad owns a business called Memory Links (www.memorylinks.com) and has to send his pieces off somewhere to get them laser engraved. My dad would most likely be very excited if I took the laser cutter to his office so he could manufacture his own Memory Links.
Fourth, I make paracord bracelets and have been wanted to put dog tags on them. I have the dog tags, just no way to put custom messages on them.
Wow, I have a lot of uses for a laser cutter! Please vote for me!
Wait! One last thing. I will also post an instructable on everything I do with the laser cutter if I win it!
Thanks!
Finalist in the
LED Contest with Elemental LED
Runner Up in the
Bicycle Contest
34 Comments
7 years ago
Yeah I made it in 2 Hours
Not sure how I'm just seeing this, but great job! The clear enclosure was a neat idea :)
8 years ago on Introduction
Can i have this circuit diagram?
10 years ago on Introduction
Congrats on being a finalist Adam! You got my vote;-)
Wait, I was a finalist? In what contest? And thanks for the vote!!!
Sorry... I misspoke. I meant congrats on being featured... Oops;-)
good luck in the Hurricane, Bike and LED contests;-)
Well, I guess you didn't misspeak... I am a finalist! ;)
Oh, that's okay! Thanks for the luck!
http://www.projectsbykec.com/projects/modifications/cyclelux
Mine isn't the most effective in the daylight either, so I am still sure to use hand signals! The only way to get LEDs to shine in the sunlight is to use high wattage ones, but they will drain your batteries pretty quick and must be properly driven with heat considerations as well. Again, great job with the whole project!
Thanks! I tried to solve the problem of the LEDs not being visible in the daylight by mounting them under my seat in the shadow.
Yeah, that should help some. Good thinking!
BTW, great job on yor bike lighting project!
Thanks, it's been a long time coming...
I think because of the reflective surface inside of the headlight you're going to run into some issues with the light looking light a blob when using turn signals.
Yeah, I though about that, but it actually works really well. Since the LEDs do not have a very wide viewing angle, hardly any reflection is seen. The bit in the video is on my first generation headlight, but it is not there in the second gen build.
i have learned alot from this best of luck for contest
Thank you!
YOU ARE AWESOME!!!!
Thanks! I learned a lot from the instructable "LEDs for Beginners" and from doing research here on instutables and posting a few questions. With a little bit of time and effort, I'm sure you could've made this too!
Thanks again for the kind words!
-Adam
Great Job will need to do this to my ride. With just a little time you could clean this up and make it look professional. A few small chunks of circuit board to mount the components to and some split looming to run the wires inside of and nobody would tell that you did this by hand. Also when doing layout for drilling the holes painters tape is your best friend. you can draw the shape using pencil and ruler until you get it right then there are no scratches on the surface. This would look awesome in those clear plastic waterproof cases for phones/wallets. Also for visibility issues consider gutting a few cheapo led flashlights. The electronics in them are trash but all we are after is the reflector and the lens. Mount them on the ends of some short pvc rods (size the pvc so the flashlight fits in a tee and epoxy the whole thing solid) so they are about a foot apart and setup a blinking red shape in the center for safety. The larger box should let you look into rechargeable RC batteries to extend the lifespan and being easy access you can always keep a spare charged one on you if you need to swap on the road. The only special trick to making everything look "Pro" is taking you time and doing it right. You're far further along than I was when I was your age. Keep learning from "trials" (or in my case mistakes), always thinking how can i make this more awesome and never be afraid to see where that takes you.
