Introduction: Bike Repair and Wash Stand
Go to your local hardware store and pick up: 3x 8 foot 2x4's, 1x small piece of ply wood, 2x base layer spray paint (I used black), whatever colors you want for designs, nails, saw, drill, tape measure.
Step 1: Step 1:
Cut the first 2x4 at 7.5 feet ( you can cut it down later if it is too tall. Then measure from the bottom, .8 inches and cut it at the angle. This will give it a flush finish when on the ground.
Step 2: Step 2:
Use another 2x4 and cut it at 6ft. When you have it at 6ft, cut that in half to make 2 equal 3 foot pieces. These will be the leg supports.
Step 3: Step 3:
At the end of the 3 foot pieces, cut it at a 45 degree angle. Place these on another piece which will give you a measurement for the middle support. Cut the middle support at 45 degrees on both sides and screw them into the 7 foot piece, while bringing them about 6 inches off the ground. When this is done, measure a support piece that will keep the screws from bending in the wood.
Step 4: Step 4:
Cut your ply wood to what will fit the length of your seat tube on your bike, and screw them in place. This gives you the weird giraffe shape.
Step 5: Step 5
Use the base spray paint and give the entire structure a thin coat, then repeat this until everything is even. Quick short bursts is what works the best. You can do whatever design you want, but I choose to tape off different parts and spray paint the different shapes. This gives it a fun and very unique look.
![First Time Author Contest](https://content.instructables.com/FYY/XTF1/K9D1QJX8/FYYXTF1K9D1QJX8.jpg?auto=webp&frame=1&width=320)
