Introduction: Bike Stereo
Build a sound system for your bicycle and entertain your friends. The speakers are designed to fit within the frame and can be easily removed. My system is powered by a battery operated mobile T-amp and an ipod. The total cost of the system is well under $100 and can be completed in a few hours.
Step 1: Required Tools
Here are some of the things you will need to get started.
1. A good pair of tin snips.
2. Velcro Tape.
3. Pliers
4. Wrench
5. Sharpie
6. Spray Paint (optional)
NOT PICTURED but still important:
7. Speaker wire
8. 1/8" line to go from the source to the amp. (mono is probably better than stereo since the speakers face opposite directions)
9. A sturdy basket. I got mine at IKEA in the bathroom section for 4 bucks.
10. A drill and a bit that will go through aluminum duct.
11. An old leather belt.
Step 2: Other Required Items - Aluminum Duct
Check your local hardware store for sheets of HVAC aluminum ducting. My local store was out so I went to Home Despot. They had several shapes and sizes. The big sheet was 7 bucks but I managed to cut two pieces out of a smalled pre-bent sheet for under 4 bucks. If you measure your bike frame first and bring the stencil you cut out you can make sure you get the right size.
Step 3: Other Required Items - Amp
Sonic Impact Portable T-Amp Digital Audio Amplifier. This is a battery powered 15 watts per channel stereo amplifier. It costs about $30 new. It runs on 8 AA batteries. I'm using POWEREX 2300 mAh NiMH rechargeables from Thomas-Distributing. They cost a bit more but you only have to buy them once and they last forever. I've run the amp at full blast for 3-4 hours without running dry.
Step 4: Other Required Items - Speakers
Sonic Impact Stick-On Speaker SoundPad Pair. These run about $20. These speakers stick to any flat surface turning it into a speaker. In this project I make two flat planes out of aluminum that fit inside my bike frame. The sound pads are concealed between them and the sound actually comes out of the aluminum!
Step 5: Other Required Items - Ipod
You will need a source for your sounds. I use and iPod wraped in an iSkin for protection. You can't be too careful these days. The best part about the iSkin is the clip on the back which I use to secure it to my $4 IKEA basket. You could easily substitute another mp3 player, a walkman, or discman. If you figure out how to put a turntable or an 8-track player on a bike, let me know.
Step 6: Other Required Items - Bicycle
You will need a bike. This is my '68 Schwinn Racer, made right here in Chicago.
Step 7: Measure the Frame of Your Bike
Using a large section of cardboard, posterboard, or paper outline the inside of your bike frame. This will help you cut your aluminum speakers to the proper size.
Step 8: Measure the Frame of Your Bike
Cut out your stencil. Now you have the shape of your frame so you can chop your aluminum down to size.
Step 9: Measure and Cut the Aluminum
Use your stencil to cut two speaker planes out of your aluminum sheet. Don't worry about the excess aluminum. It will be bent in the next step.
Step 10: Bend the Aluminum to Fit Inside Your Frame
Make sure you make each plane slightly smaller than the area of your frame so it doesn't rattle and scratch your paint.
Step 11: Attach the Straps
Cut two even parts from the belt. About 10 inches each should do. Drill 2 holes through the aluminum planes, one towards the front and one towards the rear. Use bolts with locking nuts to hold the belts in place. Hang the planes over your crossbar like saddlebags.
Step 12: Attach the Speakers and Velcro Tape
Stick the speakers on the inside of the panels. Place one higher and one lower so they will not hit each other when they are hanging back to back. I also added a strip of velcro tape around the bottom bar on my bike frame to stabilize the speakers so they would not swing side to side and hit the pedals.
Step 13: Add RCA Jacks to the Speakers
I spliced some female RCA jacks onto my speaker wire so I could easily remove my amp from my bike.
Step 14: Trim the RCA Cables on the T-amp
My Sonic T-amp came with long male RCA speaker cables. I trimed them to about 6 inches so they wouldn't get caught in the front wheel.
Step 15: Secure the T-Amp in the Basket
On my first test run, I just set the T-Amp in the basket. I hit a pothole and almost lost it. Luckily, I caught it due to my incredible Nintendo reflexes. Since then I used twist ties to fasten the battery cover to the basket. The T-Amp just clips onto the battery cover and I feed the speaker cable through the bottom of the basket.
Step 16: Attach the Basket to the Handlebars
I stick one side of the velcro tape around the handle bars. The other side wraps around the basket and attaches to the bars holding the basket in place. Rope or a strap also works pretty well. The velcro tape can be easily removed and replaced when you want to take your basket with you. I've found that the velcro sometimes needs adjusting on a long bike ride.
Step 17: Connect the Wires and Test
Plug the 1/8" line into the iPod and the line in on the amp. Plug the speakers into the amp. Slowly crank up the ipod and the amp. If either source is too loud you might get a tinny rattle. The bass isn't great but it sure beats whistling. If one or both of your speakers isn't working, try reversing the red and black wires on the speaker cables. You may have spliced them backwards.
Step 18: Give It a Paint Job (optional)
I painted mine to match my frame. I'm working on a stencil and logo to spice it up a bit more. Any suggestions?
77 Comments
6 years ago
I just used a Bluetooth speaker, a caribeener, and the straps from my bike rack. Just finished today!
8 years ago on Introduction
i made it but the speakers blew out after about a week
9 years ago on Introduction
Awesome setup!
-Jimmy from BikeBeatz
10 years ago on Introduction
This is so awesome! I had a stereo installed on my Vespa, which is very cool, but this is a must have! Thank you!
It is going to be tricky, because I have a female Schwinn! But I'll study where it's going!
11 years ago on Introduction
What if your frame doesnt have a very big opening? Cuz I ride a BMX bike and its not a very big space.
Reply 11 years ago on Introduction
Time to get a bigger bike. :-)
Haha thanks!
12 years ago on Introduction
you could put a pic of apple on it in memory of Steve Jobs
15 years ago on Step 18
excellent design. for more bass i would suggest a rear rack and a small wooden or plastic cabinet with more standard size speakers, such as those in boom boxes. once again i thought the aluminum was pretty cool how it hides the speakers.
Reply 12 years ago on Step 18
Or might I suggest a bass shaker for ~40$ with its own circle of aluminum on a rear rack. I would assume it would work as a sub, albeit a lower quality one.
That would be cool, aluminum might resonate and sound hollow or tinny though. For mine I ended up taking an altec lansing system from a computer putting the desk speakers and controls in the sub box with the sub and mounted that to a rack and hooked up a 12 volt battery. Works nicely with a little bit of rattle from the low quality sub but overall a good hit at the beach
I have a couple of T-Amps, and a pair of the original Sonic Impact fold-open 'cardboard speakers' that have those Sonic Impact transducers inside of them.
I may play around with those and make a speaker system like yours. Instead of aluminum, I'd likely try that weather-resistant material that real estate signs are made of. Kind of a plasticized or plastic cardboard. That should reduce the weight substantially, and it may be a better medium for the transducers. The Sonic Impact cardboard speakers are something similar to that stuff. I'd use hollow posts at the corners as spacers between the panels.
One thing I like about your design is that it lends itself to decoration. The chalkboard paint suggestion was good, but that's good real estate for bumper stickers or any kind of 'statement'. eg: Google 'Peak Oil' People!
Of course, I'd use a suet feeder for my electronics basket, a la my own bicycle stereo design here....
https://www.instructables.com/id/Bicycle-stereo-dashboard/
Reply 12 years ago on Introduction
Shoot. Forgot about my two water bottles in that area that make this an unlikely mod to my bike. I guess I'll stick to powered speakers.
13 years ago on Step 4
Amazon has Dayton ones for $16 a pair and some other brand for only $6 a pair! Not sure if they are of a poorer quality but they seem highly rated. Think the $6 may be a temporary sale.
14 years ago on Introduction
cool ible im getting a bmx in a couple of days! :)
Reply 13 years ago on Introduction
if anyone is looking for a forum dedicated to bicycle stereos, stop by the bikeology website's forum. the owner of the site has built some pretty ambitious & LOUD trailer systems, but we'd like ANYONE with any kind of bike system or even just interested in them to visit.
as many different systems as people have built, it would be nice to have a community that shares info & ideas as well as a common place for everyone to show their rides off & just hang out.
When you feel the need, change the price of the T-amp, and add it to my Group.
Nice 'ible! I liked how the basket is JUST big enough for your amp and ipod. I think you could be able to make the aluminum panels smaller, there is a lot of extra room in there.
15 years ago on Introduction
i just put something a little like this together, but instead of eight batteries my amp takes four and runs for about the same time.
