Introduction: Bike Trailer Tent
Bike trailer tent built from an old transport trailer and a camping bed tent
camping bed tent
2 aluminum square tubes 2.5m
3 aluminum square tubes 1m
10 safety cotter pins
2 aluminum U-profiles 1m
20 pipe plugs
approx. 90 blind rivets
1 aluminum round tube 1m
5m Tesaband
Steel angle 90°
HDF board 1.20 x 0.60m
Steel angle T
10 screws M5
10 nuts M5
Step 1: Old Transport Trailer...
Step 2: Camping Bed Tent
only the tent is used
Step 3: Remove Tube Plugs
the trailer's frame tubes are open in the direction of travel, making extension easy
Step 4: Material
Required: HDF sheet, aluminum profiles, angle joints and many blind rivets
Step 5: Frame Extension
behind the frame extension with tent holes at the ends.
Step 6: Front Frame Extension
Front frame extension with sleeping surface
Step 7: Panel
3 mm HDF panel
Top side coated, bottom side sealed
Step 8: Tent Supports
front and rear tent supports are removable for travelling
Step 9: Sleeping Surface
Sleeping surface : 194 cm x 60 cm
Step 10: Stands
Crutch assembly
These can be unscrewed to save space
Step 11: Transportation Position
The landing gear are inserted into the trailer housings and locked in place.
Step 12: Finishing Touch
HDF edge covering
Step 13: Protective Cover
Securing the protective tarpaulin
Step 14: Top
... and on top, you can also carry a lot of stuff...
Step 15: Final Assembly
Simple conversion from transport trailer to motorhome
Step 16: Rear Signalization
eye-catching rear element
