Introduction: Bike Volt
This report explains step by step how the project was constructed. Bike- Volt consists in a voltage rectifier that takes AC from a dynamo (that works with the wheel spin of a bike) and rectifies it (DC) in order to supply voltage for cellphone charging.
Materials:
-1 dynamo.
-4 diodes (1N4007).
-1 capacitor 100 uF at 35 volts.
-Tip 32C (PNP).
-Power dissipater (spider).
-Pottery resistor 2W- 100RJ
-1 regulator (LM7805).
-1 capacitor 10 uF at 63 volts.
-1 capacitor 0.1 uF at 250 volts.
-1 female USB port.
Step 1:
In a protoboard, put four diodes in the same order as picture or build a diodes bridge.
Note: Protoboard with four 1N4007.
Step 2:
Connect two wires (cathode-cathode and anode-anode) with any of the possible nodes to make a parallel circuit and wire the capacitor.
Note: The first wire is to make a positive terminal and the second wire is to make a ground terminal. Remember that is the capacitor of 100uF at 35 volts.
Step 3:
Connect the transistor Tip 32C.
Note: This transistor is a PNP configuration, so do not forget to connect it in the same order as the datasheet explains.
Step 4:
Wire the resistor in parallel with the first pin of the transistor and the last pin of the transistor.
Note: We are going to simulate that is a pottery resistor because we need it with a capacity power of 2 watts.
Step 5:
Connect the voltage regulator.
Note: Remember, first pin-input signal, second pin-ground and third pin-rectified signal.
Step 6:
Wire the capacitor, in parallel.
Note: Use the active nodes to wire in parallel the capacitor of 10 uF at 63 volts.
Step 7:
Connect the capacitor(104), in parallel to regulate the peaks of the dynamo.
Note: The 104 capacitor does not have negative or positive terminals. It does not matter the way you polarized it.
Step 8:
Connect a female usb in parallel with the capacitor (104).
Note: Check out the datasheet of the female usb for an appropriate connection.
Step 9:
This is the final step. Connect the dynamo to the circuit (cathode-anode, cathode-anode).
Note: The motor will simulate our dynamo. You can connect any AC source to have an output of 5 volts.
Step 10: URL for the Demonstration of the Circuit
https://www.youtube.com/watch?v=r5JGLj3C6l4
