Introduction: Bio Luminaire
This bio luminaire boasts an organic, captivating design that breaks away from conventional geometric shapes. Inspired by the natural world, it seamlessly blends form and function, creating a visually stunning and ergonomically optimized lighting solution.
Materials:
- Used teabag leaves
- Eggshells
- All-purpose flower
- Egg tray carton
- Food coloring
- water
Tools:
- Bowl
- Grinding bowl
- Plastic spoon
- Paper plate
- Stove
- pot
Step 1:
Using a pair of scissors, cut 210mm×300mm of thin cardboard and bend it in a shape of a cone as depicted in the image above.
Step 2:
In a bucket, soak two egg carton trays (cut down to smaller pieces) in 1 litre worth of water for about an hour.
Step 3:
Place six eggs worth of eggshells in a grinding bowl and start grinding. Grind eggshells to smaller pieces, the consistency must not be too fine. In a separate bowl, pour the eggshell grind in it. In the eggshell grind bowl, pour ten teabags worth of used teabags leaves in it and start mixing everything together.
Step 4:
Once the egg carton is soaked and soft, take it out and squeeze out any excess water and pour it out in a pot. Pour 250ml of water and put it on medium heat. After 5 minutes, pour the eggshell and teabag leaves mixture in the pot. After another 5 minutes, add 4 cups of flour and mix everything together. After an additional 5 minutes, add five drops of food colouring (colour of your choice) and mix.
Step 5:
One the mixture has cooked for 10 minutes, pour it out in a bowl.
Step 6:
Mould the mixture on the cone cardboard structure (this will be the lamp shade), Mould a 370 mm long stick (this will be the support) and lastly mould a circular base that's about 150mm in diameter.
Step 7:
After leaving the pieces to dry out in the sun for a week, assemble the luminaire. Connect the base and support using bonding glue, make a hole on the lamp shade so that the support can slide into it. Make a groove channel underneath the base so that the electrical wire can sit properly and won't make the lamp uneven when standing.
Step 8:
Finaly, Put in the electrical components.
