Introduction: Bio Fuel Briquettes, Compress Paper Pulp and Sawdust Into Fuel Bricks.
Project:
To find a use for the large amount of sawdust produced from wood turning sawing firewood etc, the 2 choices had was to dunp / compost it or burn it.
loose sawdust can be burned in a wood burner but can easily kill the fire and cause a lot of smoke. decide to try and compress it back into bricks that would burn better.
I researched the options of either dry compacting and the forces need where just to beyond my capabilities.
My only other option is to compress a wet mixture and use a binder such as news pulp.
I researched on youtube and instructables to see what the other people where using.
I found all the info needed but found some of the method where a bit fiddly for me as i have a few old hand injury's that make fiddly not an option. other option made small briquettes or the process was just to slow for the amount of sawdust i had lying around about 12 fertilizer bags full to be exact.
Ive done nothing new here, just added my 2 cents worth to the mix and try to improve what others have done before to inspire my own effort. Enjoy. :-)
Thanks for looking and I hope you like my idea
Step 1: The Plan.
Even a little bit of wood turning creates a large amount of sawdust..
I decided to build a mould that would be easy to fill and compress but would would produce a larger brick than that I had seen, and have a press that would be faster to operate.
I was lucky that I had the chance to buy a Sealy No2 bench press a few months back and had yet to fin a job for it. I decided that I could modify the pressto use for this job and more usefull for other jobs.
I decided to use only what I had at hand. this would be a no budget build.
Materials used:
3/4" plywood (I do like the 3/4" plywood)
6" sewer pipe.
Step 2: The Mould.
The mould is made from a 6" length of sewer pipe cut square on a friends band saw My own saw has only 4" throat. If have access to a few friends large saws when I need to do jobs like this.
The pipe was marked with the use of a set square the lines are the ruler blades width apart and actually worked out very evenly spaced, 5 hole where drilled at 1" intervals along each line. I used a 6mm drill bit in the pillar drill to do this, the sewer pipe is quite easy to drill.
I used the wood back plate on my wood lathe and turned 2 disks of 3/4" plywood.
One was the same as the outer diameter of the pipe with a 6mm recess cut on one edge a snug fit for the inner diameter of the pipe, this would be the base plate.
the other would be 1-2mm smaller than the inner diameter of the pipe, this would be the plunger.
That is the mould taken care of.
Step 3: Update, Better Bottom Plate
I found that the small recess I had used on the first bottom plate was starting to get built up with loose fibers of the pulp and this had lead to the ass falling out of the mould and causing a right mess and some strong language.
to solve this I made a disk with a deeper recess and a wider lip so the pipe now fits on easier and will not be able to slip off
The new disk is again made of 3/4" plywood but is recessed about 8-10 mm and is a slightly loose fit for the pipe.
Step 4: The Press
I only had to add a flat steel plate to the press, was going to do that anyway to make it more usefull than before.
A friend said he would profile me some plate steel disks for this and another lathe project. a load spreading plate on the the press would make the press more usable.
Other than add an old bike crossbar to the arm of the press to give it more leverage and get more water out with less effort.
The press is rated at about 2 tonne of pressure, the longer arm increased this so much that the solid steel arm started it bend from me pressing hay to hard, I just rotated the arm 180* and use to much force to bend it straight again. I now know the right amount of force to use not to bend the arm again.
Step 5: The Mixture and Mixer
The mixture is 2 parts sawdust to 1 part paper pulp.
Some people soak shredded newspapers over night and then mix then. some say to soak the sawdust over night, here is mu recipe.
If the heating has been on and I have hot water to spare, I use warm water to soak the paper after only about 5mins you can use the paint mixer and it will be in pulp in a few minutes, if i have cold water about an 30 mins will have it softened up and will not take long to be in pulp.
For course sawdust I just add it to the paper pulp and turn the hose into the mix until it looks about right, it should be very a very sloppy slurry so the mixer can do its stuff.
I find that very fine dust is best mixed with the pulp and then left to soaked over night.
I use builder's plaster trugs to do my mixing as they are flexible and large enough to mix a decent sized batch.
I am going to try an electric cement mixer to do the mixing which should make the job much faster with less effort.
UPDATE: I have found that for a fine sawdust you may need to add more paper pulp to the mix or the bricks will have a tendency to crumble.
Step 6: The Method
First place the mould on the the base plate firmly and fill with the pulp mixture.
level of the mixture and place the plunger on the top and gently press down.
Now carefully place the mould in place on the press without letting the base plate falling out.
And the load spreading plate if it not fixed to the press, i used on load plate at first and the plywood finally split in 2.
Press the mould until water stop running out, if you you slack of and press again only foam should press out, its just about right at this stage.
To remove the brick from the press I turn it upside down and use the rack in the press in the
up position to tap the plunger out and this forces out the brick.
Once you get the hang of things you can press a brick about ever 30 - 40 seconds, a full trug makes on average about 15 bricks.
The press needs to be clamped down to the work surface , I have the press mounted to a work bench, the bench is weighed down with 4 12" concrete blocks. the work bench is not coping well with the pressure and is now just about goosed, i need to build a very solid bench just for the press.
Step 7: And Here's Some We Made Earlier.
The pressed bricks are stacked to dry outside for a few days, if it looks like rain I cover the pile with a tarpaulin. once they are starting to dry out well I re stack then in a shed with a good air flow where they can take their time to dry out fully.
Once fully dry I move them into storage.
I have about 400 + made, and have still not used all the sawdust.
My stove is out of action and I have not got a chance to to see how well they burn, they are claimed to have the same btu value as coal but I cant say anything yet.
I did just set a dry one alight outside to see if it burned but threw it into the mixing bucket again when it started to get out of control.
I have a rough plan as how to build a box section press that would be suitable if you don't have a workshop press, if you would like to see my idea just ask and I can sketch it up and post it.
Well that my 2 cents worth on the subject.
Comments and ideas welcome.
Thanks for looking.
134 Comments
11 months ago on Step 7
Do you need to shred the paper first or can you let the water and a drywall mixer attached to an electric drill break it down? Thanks for the good post!
1 year ago on Step 7
I would love to give this a go. How can I get a copy of your rough plan for a box section press. I have so much sawdust to get rid of. Thank you.
Question 1 year ago on Introduction
I want to know which are the company uses this and where
3 years ago
GREAT IDEA
4 years ago
Hi Dr Qui,
I've been following the block making principles for a while now, so i bought a £80 twig shredder for the garden since I have so much small wood to shred every year, which in previous years i have merely burned to ash in the garden. I have three purposes for the shredded wood. 1) compost ingredient, about 1/3 of compost. 2) path lay instead of gravel, the latter becoming somewhat intrusive.
3) biofuel.
I have invested in a fire hod since putting "shred" on the household hearth fire is a bit messy, but would it be worthwhile to make blocks to give the matter more solidity or do you think making the fire with hod is sufficient. I wouldnt be adding water to shredded wood though... would I?
I've got a Stainless steel hand driven cider press which presses the juice out of apples to make what is called the "Cake" (more compost) with the juice extracted, and it also make the Cheese by extracting the Whey water from the curdled milk. More you press out the water the harder the cheese.
Do you think it would be too laborious to do this without a machine driven apparatus for fire blocks?
What I can do is estimate my Kw value from all the wood that i do shred and use on the fire before deciding to invest in a machine driven Cider press of similar make at a later date.
I only use the cider press a couple of days a year, I thought I would use it for more cheese making but hours in the day, and hygiene, make it impractical for my own use.
I certainly have 200 blocks of your size there of potential chippings to get on with at the moment, but will be a long job both the shredding and the blockmaking, but worthwhile in energy saving for this 1/3 acre, 1/6ha, which has many trees and shrubs. Happy block making!! Gar
Reply 4 years ago
Gareth, may I ask what is a fire hod?
4 years ago on Introduction
Thanks very much for your excellent effort it will help
6 years ago
Thank you its really helpful, i want to do lots,but dont have the money to buy a mechanical one plus just a million reasons why. all said and done i must start somewhere and your plan is perfect!!
6 years ago
I'll love to try it but can it be done at a bigger scale to create employment for community an keeping the environment clean buy using the garbage to produced something useful
7 years ago on Step 7
what about using a wood splitter/ hydraulic as a base for the press??
Reply 6 years ago
7 years ago on Introduction
it is true that the briquetting system needs high pressure to agglomerate the powders & fines. To know more about briquetter. http://www.briquetter.cn/
Reply 6 years ago
check this two tonne baby out
6 years ago
Love the instructable. Have softwood chips with horse manure composting on heap plus small quantity of household paper and cardboard plus some woodshavings (hardwood). Any ideas about making briquettes and what proportion to start with.
They seem to use animal waste in some parts of the world.
Reply 6 years ago
we have sold one to a larma farm!
6 years ago
6 years ago
Could you please give a video of these being burned ?
Business Opportunity: Industrial paper dust is a problem for lots of factories. They have to use a dust collector to keep it out of the air and then typically bail it, but it's too fine for recyclers to be interested in. The bales usually end up in a landfill. If anyone's interested in making lots of these, the dust should be a steady, free source that would cut out the shredding/blending work. If you're in the Birmingham, Alabama area, and would like some to try, just reply to my post.
Reply 6 years ago on Introduction
Hey Matt!
I do not live in that area, but think that that would be a really interesting way to reduce and reuse some waste. What kinds of factories should I ask about taking their paper dust off their hands? Or is more of a common problem that I could just ask around and likely find some people willing to help me out?
Thanks,
Scott
Reply 7 years ago
Matthew, I think that's a great idea. could you msg me on kik?
