Biodegradable Flower Pots Out of Coffee Grounds!
Intro: Biodegradable Flower Pots Out of Coffee Grounds!
Did you know coffee grounds still have a lot of good uses after they've been used?
In this instructable we'll make a flower pot that is completely biodegradable.
This means that you can put the plant with the pot in the ground when the plant has withered.
It is biodegradable because the base materials are water, flour and coffee grounds (a good compost material).
These pots are easy and fun to make and are ideal for kitchen herbs that can later on be planted in your garden.
Optional:
- Create your own pot shape (Step 4)
- Add your own logo (Step 5)
This instructable is part of a system called Coffee Cycle:
Bike pannier (front & rear)
Coffee grounds collector
Burlap sack for bicycle basket
Tell me more about the Coffee Cycle project!
Optional:
STEP 1: Materials
Materials for one flower pot:
- 1 cup of flour
- 1 cup of coffee grounds
- 1/2 cup of water
- Biodegradable flower pot
- Plastic container
Optional for a logo:
- Balsa wood
- Carving knife
- 1 cup of flour
- 1/2 cup of water
- Plastic container
- Balsa wood
- Carving knife
STEP 2: Mix the Coffee & Flour
Add one cup of flour and one cup of coffee grounds to a container.
Stir well until you become a light-brownish even mixture.
STEP 3: Add Water
Add water in small amounts to the mixture. Stir well each time. The end result should have a muddy texture.
STEP 4: Coat the Flower Pot
Coat the biodegradable pot with the mixture. Make sure you leave no gaps and the mixture is spread even all the way around.
Flatten the top (the pots bottom) so the pot wont be able to tip over.
TIP: Instead of using a biodegradable pot, you can also use an existing pot or create your own pot (create a mould out of clay or plaster).
You will need to remove the existing pot / mould after baking to maintain the biodegradable aspect.
STEP 5: Design Your Own Logo (Optional)
Draw your logo on a piece of paper and cut it out. Transfer it on the balsa wood (or choose an other material) by pencil or just carve around your paper drawing. Sand of the rough edges that might be left over.
Place the balsa logo on your flower pot and press gently.
STEP 6: Bake!
Your environmentally friendly flower pot is now ready for the oven!
Bake the pot for 40 minutes at 120 degrees Celcius (or 248 degrees Fahrenheit).
The end result should be sturdy and is pretty water resistant.
Incase you want a full water resistance, you can apply a biodegradable varnish layer on the inside.
34 Comments
aysekaplan204 1 year ago
**This open design projects were done as part of the ID736 Open Design and Distributed Creativity course, at the Department of Industrial Design, Middle East Technical University, in the 2021-2022 Spring semester.
williamcastille 7 years ago
If you used egg white as a binder would that make it more water resistant?
Skiprose83 4 years ago
antioch 10 years ago
Suggestions for biodegradable varnishes please!
mvillalpando 10 years ago
Modge Podge...check on your arts and crafts for the biodegradable one, there are many versions of Modge Podge, but I am sure that they have one that is biodegradable; I bought it last year to seal some ceramics that I used to place food on.
abunda 4 years ago
WalkSoftly77 8 years ago
ella868 9 years ago
bellashanna 9 years ago
this is an amazing way to re use coffee, I have made the pots, but can you please tell me what do I need to do to stop the pots from going mouldy. After I plant them out and water them, a few days later white mould starts to grow on and in the pot.
einon 8 years ago
Did you make a hole in the bottom for drainage????
jmnyquist 10 years ago
It would be fantastic, if you could help me understand why the 40/40/20 (2:2:1) mixture of grounds, flour and water. Would you have suggestions on why a muddy texture rather than a clay like texture? After they've been baked, what's a safe limit on the volume of water before they return to mud? Do you have suggestions for the thickness of the mixture prior to baking?
I can definitely see doing this with a glazed pot as a mould to make separation easier. I, like others, would think the purpose was to not invest in manufactured biodegradable pots that, although not very attractive nor necessarily sustainably produced, serve their functions well. The idea of using one of those as the inner liner not to be removed seems slightly wasteful.
TVG3000 10 years ago
I wrote muddy texture because this sticks better to the biodegradable pot. You could also add less water and work with a more clay-like texture if the mould you are working with allows it.
If you give your plant a fair amount of water the pot will absorb it and will become flexible. You can let it dry afterwards and it will return to normal. But if you want to water your plants a lot we advise you to work with a biodegradable varnish.
We worked with a thickness of 6-8mm if I remember correctly.
The idea for these pots was to use them for plants (herbs) that you keep 1-2 weeks inside your house. Afterwards you can plant your herbs with the pot in your garden or throw them in your compost bin.
Due to the time, materials, and energy involved, I must be adamant that it's more sound to spend a few coins more for the larger readily available biodegradable pots than to use this for making the smaller cheaper ones to become prettier or larger. That said, I consider part of your goal in posting this is minimizing environmental impact, and using a reusable mould in place of the biodegradable core should be paramount to that effect.
I believe this to be a wonderful concept and look forward to implementing. Thank you for sharing the ideas, I think what you're doing is great.
dskinner5 10 years ago
Hi,
I think it would work on a Potter's wheel if you use an inside mould. I also think this mix wont stand on its own without an inner support before it is baked (it will collapse). You could indeed experiment with other doses of flour and grounds.
Maybe mix grounds with clay?
Please post your findings if you are experimenting with it, I'm interested in the results!
TheCheesemakersWife 10 years ago
You could probably take a pyrex glass, like a measuring cup, and use it as a mold for baking. You wouldn't get many done at a time, but it could work.
