Introduction: 3D Printed Ultimate Biplane 10-300S (RC Plane)
I have designed this plane from scratch using the software Catia. This plane was specificly designed for 3D printing, which means that it is very light (about 400 grams without electronics). There are .stl files of every part that is used on this plane (except the wooden beams - you have to buy them). To build this plane, you will need a 3D printer, some skills with building RC models, and a lot of time, but it is worth it.
Step 1: Creating the Digital Prototype
You don't have to do this, it is already done. It just for you to imagine how this plane was created.
Step 2: Print and Glue Together
Print the parts you need, assembly them together and glue. I used the epoxy, and it is perfect.
You will need:
- 3D printer
- epoxy
- wooden beams (3x3 mm)
- balsa (for ailerons)
T8 obluk_export.gcode
VystuhaSS1.stl
VystuhaSS1.gcode
vpredu stred_export.gcode
vpredu stred.stl
velky trojuholnik_export.gcode
velky trojuholnik.stl
velky trojuholnik.gcode
velky podvozok_export.gcode
velky podvozok.stl
velky podvozok pravy_export.gcode
velky podvozok pravy.stl
V1-2 tlac tiahlo_export.gcode
V1-2 tlac tiahlo.stl
trojuholnik.stl
T8_export.gcode
T8.stl
T8.gcode
T8-obluk_export.gcode
T8-obluk.stl
T8 obluk.stl
T2--1- Copy.stl
T2 -skuska_export.gcode
T2 -skuska.stl
T2 -skuska.gcode
T2 - Copy.stl
T2 - Copy.gcode
Symmetry of drziak_prazy_export.gcode
Symmetry of drziak_prazy.stl
stvorec_export.gcode
stvorec.stl
sp1-2 tlac_export.gcode
sp1-2 tlac.stl
sp1-1 tlac_export.gcode
sp1-1 tlac.stl
skuska_export.gcode
skuska.stl
skuska.CATPart
rebro_export.gcode
rebro.stl
rebro.CATPart
rebro uchyt.CATPart
rebro - Copy.CATPart
pokus_export.gcode
pokus.stl
poh. smer. 1_export.gcode
poh. smer. 1.stl
Part51_export.gcode
Part51.stl
Part51.gcode
Part51.CATPart
paka_export.gcode
paka.stl
ovladanie kridelok_export.gcode
ovladanie kridelok.stl
otvor predok horok_export.gcode
otvor predok horok.stl
ostroha_export.gcode
ostroha.stl
obluk_export.gcode
obluk.stl
obluk podvozok_export.gcode
obluk podvozok.stl
Nos_v2_export.gcode
Nos_v2.stl
Nos_v1_export.gcode
Nos_v1.stl
Nos_v1-zrezany_export.gcode
Nos_v1-zrezany.stl
Nos_export.gcode
Nos.stl
lavy uchyt trupu_export.gcode
lavy uchyt trupu.stl
lavy uchyt trupu verzia 3_export.gcode
lavy uchyt trupu verzia 3.stl
lave_rebro_export.gcode
lave_rebro1_export.gcode
lave_rebro1.stl
lave_rebro.stl
lave rebro ovladanie kridelka pant_export.gcode
lave rebro ovladanie kridelka pant.stl
lave chytenie trupu verzia 2_export.gcode
lave chytenie trupu verzia 2.stl
kryt_export.gcode
kryt.stl
kryt.gcode
kryt v4_export.gcode
kryt v4.stl
kryt motora_export.gcode
kryt motora.stl
kolik_export.gcode
kolik.stl
drziak_prazy.stl
drziak motora_export.gcode
drziak motora.stl
drziak kamery_export.gcode
drziak kamery.stl
drziak baterky_export.gcode
drziak baterky.stl
T8 obluk.stl
T7 obluk_export.gcode
T7 obluk.stl
T6 obluk_export.gcode
T6 obluk.stl
T5 tlac_export.gcode
T5 tlac.stl
T4 tlac_export.gcode
T4 tlac.stl
T3 tlac_export.gcode
T3 tlac.stl
T2 tlac_export.gcode
T2 tlac.stl
T1 tlac_export.gcode
T1 tlac.stl
T 4.5_export.gcode
T 4.5.stl
obluk 1 tlac_export.gcode
obluk 1 tlac.stl
S-S1_export.gcode
S-S1.stl
S-S1-2_export.gcode
S-S1-2.stl
poh. smer. 2_export.gcode
poh. smer. 2.stl
poh. smer. 1.stl
ukoncenie folie_export.gcode
ukoncenie folie.stl
uchyt stred servo_export.gcode
uchyt stred servo.stl
stredove rebro_export.gcode
stredove rebro.stl
stredove rebro lave_export.gcode
stredove rebro lave.stl
spojka_export.gcode
spojka.stl
spojka vyskovka_export.gcode
spojka vyskovka.stl
spojka horna_export.gcode
spojka horna.stl
S-S1_export.gcode
S-S1.stl
S-S1-2_export.gcode
S-S1-2.stl
pravy uchyt trupu_export.gcode
prave rebro_export.gcode
prave rebro.stl
prave rebro kridelka.stl
prave rebro kridelka pant ovladanie_export.gcode
prave rebro kridelka pant ovladanie prpisane_export.gcode
prave rebro 1_export.gcode
prave rebro 1.stl
paka_export.gcode
paka.stl
lave rebro_export.gcode
lave rebro.stl
lave rebro prepisane.gcode
lave rebro kridelka_export.gcode
lave rebro kridelka.stl
lave rebro kridelka pant_export.gcode
lave rebro kridelka pant.stl
lave rebro kridelka pant 2ks_export.gcode
lave rebro kridelka pant 2ks.stl
lave rebro 4ks_export.gcode
lave rebro 4ks.stl
lave rebro 2ks_export.gcode
lave rebro 2ks.stl
lave rebro 2ks.gcode
drziak_prazy_export_prepisany.gcode
drziak_prazy.stl
drziak kamery.stl
drziak kamery 4ks_export.gcode
drziak kamery 4ks.stl
chytenie serva1_export.gcode
chytenie serva1.stl
chytenie serva 2_export.gcode
chytenie serva 2.stl
V1-2 tlac_export.gcode
V1-2 tlac.stl
V1 tlac_export.gcode
V1 tlac.stl
S V tlac-2_export.gcode
S V tlac-2.stl
S V tlac-1_export.gcode
S V tlac-1.stl
S V tlac-1 prava_export.gcode
S V tlac-1 prava.stl
poh. smer. 2.stl
dolne kridla A2.pdf
zostavny vykres A1.pdf
vyskovka A3.pdf
horne kridla A2.pdf
trup lietadla A1.pdf
smerovka A3.pdf
Step 3: Coating
I have used the ironing foil Oracover. Top is transparent red, and the bottom is pure black.
You will need:
- Ironing foil
- sharp knife
- flat-iron
Step 4: Finish
There is also an idea how to box this plane when you need to travel with this plane. You wil need a huge box (I guess this one is from some graphic plotter).
Step 5: Fly and Enjoy
Nobody is perfect....
But, you can check out the new face-lifted version of my 10-300S here: https://www.instructables.com/id/Repairing-Crashed-3D-Printed-Biplane-10-300S/
