Introduction: Bird Apartments
This project is a step by step process on how to create bird apartments.
For this project you need one 2x4, a table saw, power drill,stain/torch and wood glue.
Step 1: Cut 2x4
Cut your 2x4 into 1/4" pieces.
Step 2: Cut 12 7" Pieces
Cut 12 7" pieces, these pieces will be your walls.
6 of them cut straight. The other 6 pieces cut at a 45 degree bevel.
Step 3: Cut the Beveled Pieces
Cut the beveled pieces to 6" long.
Step 4: Cut the Straight Edge Boards
Cut the 6 straight edge boards to a point
Step 5: Cut Roof Pieces
Cut Roof pieces to be 4" long, at a bevel of 45 degrees.
Step 6: Put Walls Together
Put walls together, be sure beveled pieces are glued on the side of pointed walls.
Step 7: Cut Hole in Walls
Cut hole in walls on 3 of the pointed walls. Do so using a power drill and a hole cutting bit.
Step 8: Put Roof Pieces On
Put Roof pieces on.
Step 9: Burn or Stain Your House
Burn or stain your house. This step is not required but suggested to make your apartments look nicer.
Step 10: Add the Final Finishes
Add final pieces you want for your bird apartments.
Connect the apartments and add a bottom as well.
