Introduction: Bird Blaster
This will show you how to create a blaster which you can shoot a cardboard bird out of and it is really simple
Step 1: Cut Out the Bird
First you can cut two 1-inch by 1-inch triangles in the cardboard and a 1 by 1 inch square in the cardboard
Step 2: Continue Cutting
Next what you want to do is cut a 2/10 inch by a inch rectangle and a 1 centimeter by 1 centimeter triangle
Step 3: Glue
Next what you should do is glue them together to make a bird by glueing them all together
Step 4: The Beginning of Flight
First you grab your pen with springs inside and take it apart next take the part that holds the ink with the spring put it in the tip of the pen in a way you can shoot the ink holder out of.
Step 5: Take Off Procedures
Use the the ink chamber to stab the bird through it's back and hot glue it there
Step 6: Take Off
You compress the spring to fire
