Introduction: Bird Feather Rainbow Loom
Please leave comments to tell me how i did and what i can do better
Step 1: Materials
You will need:
1) rubber bands
2) hook
3) loom
4) clip
5) pencil (optional)
1) rubber bands
2) hook
3) loom
4) clip
Step 2: Loom
Fix your loom so it is in a straight line.
Step 3: Frame
Take whatever color you are using and out line the loom.
Step 4: Looming
Take a new color. The one you want to be the middle. Only put one down.
Step 5: The V
Put a band from the middle peg to the second peg on the left in a different color. Do the same to the right side.
Step 6: Repeat the V
Keep repeating steps four and five until you get to the end
Step 7: Backwards V
Make a backwards V. Look at picture for help.(the yellow)
Step 8: Repeat
Repeat step seven until you get to the end
Step 9: Cap
Make an eight with your outlining color. Put on side on top of the other. When you are done it will look like two circles on top of each other. Place that at the end of the loom you didn't started on.
Step 10: Banding
Go underneath the cap band and grab the yellow (whatever color you used) and bring it to the side it came. Do the same to the other side.
Step 11: Bring
Bring up the pink (whatever color you used) and bring it up
Step 12: Again
Repeat steps 10 and 11 until the end
Step 13: Frame Looping
Now go back to the end you put the cap on. Take the bottom blue (whatever color you choose) and bring it to the side it came from. Do again to the other side.
Step 14: Frame Looping
Go to the first side you hooked. Take the bottom frame rubber band and loop it to the peg in front
Step 15: Repeat Frame Looping
Repeat the looping until the end of the loom
Step 16: B)
Step 17: Almost
You are almost done. All you have to do is bring the bands from the two side on both ends of the loom
Step 18: Clip
Put a rubber band through all of them on the end. Put another rubber band through that and add your clip go the other side and make a chain off the end (chain in previous instructabe) and pull off
