Introduction: Bird Park
In this project we will be making a bird park from cut of tree branches and plywood. We will be needing around 1m by 1m block of plywood. We will also be needing some jute rope and a wired rope.
you will need a saw, hammer and an air Nailer.
Step 1: The Base and House
So take the plywood and measure a 50cm by 50cm square. cut it out using the saw. After that take the plywood and measure 4 rectangles that are 5cm by 10cm. Next cut them out and sand all the plywood pieces.
Step 2: Putting Together the House
Take the four rectangles and the Air Nailer then nail the rectangle together. after that attach three cut tree branches at 15 cm each and nail them to the bottom of the ractngles. After that nail the house to the platform.
Step 3: Adding the Tree Branches
Take three tree branches and nail them to the platform nailing from the bottom. Before Nailing the Tree branches take of all the leaves. Now you have the tree branches for your bird.
Step 4: Making the Ladder
To make the ladder take two 20cm strings of jute rope and then add the wires connecting the two strings and forming the ladder. After that nail one end of the ladder to the house and the other to the bottom of the platform. Now you have the ladder.
Step 5: Making the Bridge
take two strips of wire and attach them to the tree branches near the bottom then after that tie the jute rope around and there you go you have the bridge.
Step 6: Making the Swing
so take two pieces of straight branches at 32 cm and take off all the excess leaves. then cut of a 15cm branch and drill two small holes so you can put some wire through. After that take a thin branch at 13cm long and also drill two holes on the sides. After that take the 15cm piece of branch at put wire through it and on the end tie a knot so the wire doesn't fall out. then put the wire through the thin branch and also tie a knot at the end of each wire so the swing doesnt fall out this is the final step.
