Introduction: BiroHero-BUILT ON BOLT
Meet Birohero who will outwit the criminals. I always have a passion to work on IoT projects and I finally did it.
This project uses LDR which will output a low value when the thief is near the biro which indicates the presence of thief.
This project contains
1.Arduino uno
2.Ultrasonic sensor
3.Bolt iot platform.
4.led,resistor.
5.LDR.
Step 1: Step 1: Setting Up Ultrasonic Sensor.
Write program for setting the ultrasonic sensor. I configured the sensor to detect the object within 100cm. I have attached my program for arduino.
Step 2: Step 2: Making the Connections As Per the Diagram.
Step 3: Step 3: Camera
Make use of any smartphone to outwit the thief. Install "IP webcam" app on playstore. Also intsall it on your pc. I attached a link which gives useful information on setting the smartphone cam.
"https://www.cnet.com/how-to/how-to-use-your-android-as-a-webcam/"
Step 4: Step 4: Create Bolt Graph
Write a program to display line chart on bolt cloud. This will be easy when you have attended the bolt workshop.
Step 5:
Your smart biro is set to go. But this project has various constraints.
NOTE: In the video, I have said turning night vision mode helps. But camera remains dark after turning on night mode . I have done turning night lamp on without affecting the LDR data.
