Introduction: Black Cat Minecraft Statue
Today I will be showing you how to make a fun and easy Minecraft Cat Statue.
You need these supplies:
Block of Coal
Stone
Pink Wool
Lapis Lazuli Block
Red Stained Clay
Block of Quartz
You can also use wool:
Grey Wool
Light Grey Wool
White Wool
Pink Wool
Red Wool
Blue Wool
Step 1: The Legs
For the legs, you need to make two nine block high pillars that are two blocks apart. They need to be two blocks thick and two blocks wide.
If you look at the picture, you can see the pattern of black and white.
Step 2: Body
Now, to make the body.
It is hard to explain, but the bottom part should be 3 blocks high. You can just copy the picture.
Step 3: Head, Collar, and Tail
For the collar, you can put it one block in atop of the body.
Then, you can make the head over that. What I did was put stone on the bottom, then pink wood above it. I then put two Lapis Lazuli blocks for the eyes.
Then, I made the tail a slanted line with quartz on the end.
Step 4: Finish!
Now, you are done!
