Introduction: Blind Helmet
Blind people use a white helmet as a tool for direction, when they move or walk.Here, we develop a tool which can serve as a blind helmet being more efficient and helpful than the conventional one.
This project is made in khera jattan Nook
Name of makers
Rajveer
Gurdeep
Daman
Step 1: Material
1. Arduino uno
2. Ultrasonic sensor
3. Buzzer
4. Battery
5. Switch
6. Battery caliper
7. Specs
8. Jumper wire
9. Dabble tape
10. Cardboard helmet
Step 2: Arduino Connect to Ultrasonic Sensor
First, take Four jumper wires and put them in ultrasonic sensors.
VCC - 5v
Trig - 13
Echo - 12
Gnd - Ground
Step 3: Arduino Connect to Buzzer
Buzzer positive wire to connect Arduino pin 7
Buzzer negative wire to Arduino Ground
Step 4: Arduino Connect to Battery
Battery positive wire to connect Arduino pin V1n
Battery negative wire to Arduino Ground.
Step 5: Fix It
Arduino Uno, Battery, ultrasonic sensor and switch added to the helmet.
Step 6: Arduino Cord
Now its time for uploading the sketch.The sketch for the Arduino is given below, copy this into your Arduino IDE, then upload into your Arduino
#define trigPin 13
#define echoPin 12
#define motor 7
#define buzzer 6void setup(){pinMode(trigPin, OUTPUT);pinMode(echoPin, INPUT);pinMode(motor, OUTPUT);pinMode(buzzer,OUTPUT);}void loop(){long duration, distance;digitalWrite(trigPin, LOW); delayMicroseconds(2); digitalWrite(trigPin, HIGH);delayMicroseconds(10); digitalWrite(trigPin, LOW);duration = pulseIn(echoPin, HIGH);distance = (duration/2) / 29.1;if (distance < 70)// This is where checking the distanceyou can change the value{ digitalWrite(motor,HIGH); // When the the distance below 100cmdigitalWrite(buzzer,HIGH);} else{digitalWrite(motor,LOW);// when greater than 100cmdigitalWrite(buzzer,LOW); } delay(500);}
