Introduction: Blink a Series of LEDs Using Python Programming Language and Raspberry Pi
In the first phase, I will install only one LED. Next, I download the LED class python module that represent one hardware LED. I will run the LED class python module to blink that LED. The first phase serves as a "Proof of Concept".
In the second phase, I will install another 4 LEDs. Finally, I run the python main module to create a series of five sequentially blinking LEDs as depicted in the video above
Step 1: Materials
Gather the following materials:
1 Raspberry Pi device running on standard Raspbian Linux installation
5 LEDs rated at 2.4V
5 Resistor (can be between 185 Ohms to 270 Ohms)
5 single-core wire (also called solid wires, solid-core or single-strand wire, consists of one piece of metal wire. Solid wire is useful for wiring breadboards. I stripped an unused telephone wire to get the single-core wire. There are 4 thin insulated single-core wire in a telephone cable. Choose any one and strip the insulator off just enough to expose bare metal at the two ends.)
Step 2: Installing the First LED
Be careful when installing the LED with the Raspberry Pi as it may short-circuit and damage Raspberry Pi device. Do this at your own risk. Remove all power supply source from your Raspberry Pi device.
MaterialsThe following materials are required:
1 X Raspberry Pi
1 x LED
1 X 165 Ohm Resistor
2 X Male-Female Jumper Wire
1 X 5cm single core wire 1 X Breadboard
Installation- Read to the GPIO diagram to locate the pins.
- Connect female end of jumper wire to the GPIO Pin 11. (This pin will be programmed to supply 3.3 Volts)
- Connect male end of jumber wire to the breadboard as shown in video.
- Connect resistor to breadboard as show in video.
- Connect LED to breadboard as shown in video.
- Connect the single-core wire as shown in video
- Connect female end of another jumper wire to GPIO Pin 6 (This pis is at 0 Volts.)
Step 3: Start Up Raspberry Pi
- Boot up the Raspberry Pi by pluggin in the power supply micro usb
- Log in using pi account
Step 4: Use a Python Class Module to Flash an LED
- Load the LXTerminal.
- Install or update the Rpi.GPIO software by typing the following bold commands. The command might ask you for your input:
pi@raspberrypi ~ $ sudo apt-get update
pi@raspberrypi ~ $ sudo apt-get install python-rpi.gpio
- Download the attached file called led.py and saved it as led.py in Raspberry Pi directory: /home/pi/python_proj/gpio
- Load the IDLE by typing the following:
pi@raspberrypi ~ $ sudo idle - On the IDLE's Python Shell Window: Click File -> Open -> Choose led.py that you saved in #1 of this step
- Read the documentation and source codes of led.py.
- In IDLE's Python Shell Window, type the following
>>>import sys - Then press ENTER
- Type the following:
>>>sys.path.append('/home/pi/python_proj/gpio') - Then press ENTER
Type the following:
>>>import led- Then press ENTER
Type the following to setup the LED connected to Pin 11:
>>>led11 = led.Led(11)- Then press ENTER
Type the following to blink the LED connected to Pin 11:
>>>led11.blink_non_stop()
- Then press ENTER key
- Observe that the LED blinks continuously.
Press Ctlr+C to exit program
Type the following:
>>>led11.clean_up()- You have successfully completed the "Proof of Concept" phase if the LED blinks continuously.
Step 5: Install and Test the Next 4 LEDs
You need the following:
4 x LED
4 X 165 Ohm Resistor
4 X Male-Female Jumper Wire
4 X 5cm single core wire
Installation- Shut down Rasbian OS
- Unplug the power cable off Raspberry Pi
- Follow the same instruction described in Step 2.
Use the following GPIO Pin:
Pin 12
Pin 15
Pin 16
Pin 18- Play the attached video for detail to see the layout of the components in the breadboard and Raspberry Pi
- Load the IDLE (Python Editor) by typing the following:
- In IDLE's Python Shell Window, type the following:
>>>import led - Then press ENTER
>>>led12 = led.Led(12) - Then press ENTER
>>>led12.blink_non_stop() - Then press ENTER key
- Observe the LED blinks continuously.
- Press Ctlr+C to exit program
>>>led12.clean_up() - Repeat instructions No 11-15 for the rest of the LEDs. Remember to change the Pin number for each LED:
led15 = led.Led(15)
led16 = led.Led(16)
led18 = led.Led(18)
Step 6: Blink the Series of LEDs
- Download led_effects.py and led_main.py and save the 2 files as its original name in /home/pi/python_proj/gpio
- In IDLE's Python Shell window, click Menu -> Open -> Choose led_effects.py
- Read the source codes
In IDLE's Python Shell window, click Menu -> Open -> Choose led_main.py
- In the window that displays led_main.py, click on Run -> Run Module
- Observe all 5 LEDs blinking in sequential order
5 years ago on Introduction
is it all right if u can post the code too, that would be awesome!
