Introduction: Blinking Led Light(with Potentiometer to Adjust Blink Rate)
Author: Simon Merchan
Meant for: Any level
Material
- Breadboard
- Wires
- 9v battery
- 9v battery strap
Compentents required
- 555 timer
- Capacitor 100uf 25v
- 2 led lights (any color)
- 200k resistor
- 10k resistor x2
- Potentiometer (any K measurement)
Anyone at any level can do this circuit IF you follow step by step with picture provided to visual assist. It also gives an idea on how it’s supposed to be. Give this circuit a shot now!
Step 1: 555 Timer
Set bread board on table. Then, place the 555 timer in the middle of the breadboard (should be connected inside both sides of dots)
Note: Make sure it's 555 timer or circuit will not work
Step 2: Wire Over 555 Timer
First, connect pin 2 of left side to pin 3 of right side of 555 timer; Secondly, connect pin 4 of left side of 555 timer to pin 1 of right side
Step 3: Add the Resistor
Connect pin 2 of right side of 555 timer with a side of 200k resistor and other side to the positive aspect side of breadboard
Note: Anything less than 200k resistor will not work. It will only lead to the led lights turning on and not blink at all
Step 4: Potentiometer and Wiring Time
Place potentiometer somewhere on bread board that is not next to 555 timer; afterwards, connect left side of potentiometer to 2nd pin of right side of 555 timer; lastly, connect middle of potentiometer to 3rd pin of right side of 555 timer
Step 5: Capacitor Time
Connect 100uf with negative side to 2nd pin and positive side to 1st pin in the left side of 555 timer
Note: Black strip of capacitor is the negative aspect
Step 6: More Wiring Time
Connect the 1st pin of the left side of 555 timer to negative power aspect of board and connect the 1st pin of right side to positive power aspect of board
Step 7: Led Light Time
Place led light anywhere on board but with short side leg connected to the negative power aspect of board
Step 8: Lets Finish Off the Resistors
Connect long side leg of led light to 3rd pin of left side of 555 timer with 10k resistor(repeat this with other led light)
Note: Any resistor will do. Anything above 10k will increase blink rate and decrease brightness. Anything below 10k will decrease blink rate but increase brightness
Step 9: Light It Up
Lastly connect battery to power aspect of board. It should turn on. If so, move potentiometer to adjust blink rate to your desire. If able to do so, circuit is up to standards!
Troubleshoot:
If it does not turn on….
· Check if wire is plugged in all the way
· Try different battery
· Try different potentiometer
· Try different led lights
If led lights turns on only….
· Try different resistors above 200k
· Check your wiring from previous steps and make sure it's on point
Go on and try other circuits found on my homepage such as how to build a circuit of brightness adjuster for led lights or how to build a circuit of led light chase using only a 555 timer and ic4017!!!
