Introduction: Blinking Lights
This project was inspired by and is a modification of the project "Multiple Blinking LED on the Arduino". As a person who has a plain room, I wanted to decorate it and make it a bit more colorful. Furthermore, I modified the project by adding one more LED light as well.
Reference: https://www.instructables.com/Multiple-Blinking-LED-on-the-Arduino/
Arduino Board(Any compatible board is fine)
Bread Board
4 LED light bulbs
Jump Wires
Step 1: The Code
This is the code for the project, made by The Electrodog Show and modified by me.
Code Link: https://create.arduino.cc/editor/blanc35/a7934b5b-5421-4ce5-a32a-21eb97045213/preview
Step 2: Setting Up the Circuit
Connect one jump wire to each of the following 4 numbers; 13, 12, 11, 10, following the placement, place the other end onto different parts of the breadboard. After connecting the four jump wires, connect another jump wire leading from GND to the negative power. Then connect a jumper wire from the GND, leading next to the jumper wire from the 4 numbers to the breadboard. So in total, there should be 9 jump wires used. Then you could insert the 4 LED lights of your choice onto the breadboard.
Step 3: Finished Results
This is a video of the actual product. Enjoy!
