Introduction: Blinking Shark Puppet
How to make a shark puppet with blinking LED lights for its eyes!
The two LED lights are going to turn on when the shark's mouth is closed the first time,
after the first time the lights come on, the LEDs are going to blink when the mouth is closed.
Step 1: Preparation
Things you need
- Lilypad
- Fabric
- Scissors
- Multi meter
- conductive fabric
- Conductive thread
- Needles
- Snaps
- Alligator clips
- Heat bond (not in the photo)
- Iron (not in the photo)
Step 2: Cut the Shark Pattern
Cut the pattern of the shark out of materials you desire.
I used felt this time.
pattern credits to : AMIE SCOTT
Step 3: Make a Soft Switch Using Conductive Fabric
Make a switch out of two conductive fabrics.
There are 3 parts to this switch, 2 conductive fabric contacts and a spacer in the middle.
Cut the conductive fabric into appropriate sizes with little tabs on the bottom for easier connection with the Lilypad later on.
Spacer has two holes in between so the circuit is completed (switch is on) only when the two conductive fabric meets.
I'm placing the switch where the shark's mouth is.
Step 4: Construct the Shark
Keep on sewing and construct the shark.
Step 5: Work on Circuit and Your Sketch
Work on the circuit first with the alligator clips before transferring it to the fabric
I put on delays between the LEDs on and off to create a blinking effect
Step 6: Lilypad Connection Using Snaps
There are many ways to transfer circuit to fabric.
I used snaps and conductive thread for this puppet.
Snaps are a good way to attach the Lilypad onto the fabric and as a way of closing the circuit.
Each snaps are sewn in pins where there is a connection.
You can mark where the snaps are placed and sew the counter part of the snap on the shark.
Step 7: Sew LEDs and Snaps Using Conductive Threads
Using conductive thread, connect LEDs. They are connected to pin 5, 10.
Make sure the connection is tight and secure.
Step 8: Make Space to Store the Battery
Make a mini battery pocket that can be sewn next to the Lilypad.
I used felt and hotglued it into a pocket.
Step 9: Iron on Heat N Bond to Insulate the Conductive Threads
The threads needed to be insulated so the short circuit doesn't happen when you put on the puppet.
Heat n bond is a good material to insulate as it is fast and easy to apply to the fabric with iron.
Heat n bond is ironed on over the thread paths to prevent them from touching each other and short circuiting the circuit.
Step 10: Flip the Shark Inside Out and Run the Code
Once you have everything connected, you can now turn the puppet inside out and play with it!
Step 11: Finished Shark!
yay! You can play around with how fast the LEDs blink.
2 Comments
6 years ago
Cute!
6 years ago
Cool puppet design.
