Introduction: Blinky the LED Pet
But there's one issue always on Blinky's little, five-component brain: He is alone, and would love to get in touch with other led-based creatures. Here's a video:
Blinky asked me to set up this instructable, so that other people can make him a friend.
Making Blinky a friend won't cost you much:
- a couple of hours of your time and patience
- approximately €12 / $16
(but you might find everything you need in your basement)
- Some everyday tools
In the five steps described, you'll find everything you need to know to create a friend for Blinky. He can't wait to meet the results of your efforts...
Update Feb 2011: I made Blinky a friend. He's called Monster 555.
Step 1: Tools and Materials
Also take a look at the photo's and the comments. I tried to make the pictures as self-explanatory as I could...
Materials used for building Blinky's body and legs:
- A lot of electric wire connectors: 60 stubs or so (€3 / $3,60)
- A couple of meters of solid kern electrical wire (€2 / $2,50)
- Tie-raps
- A piece (30 x 30 cm) of furry fabric
- Double sided foam tape
- 9 Volt battery block
For Blinky's head:
- a 9 x 5 cm plugin board for electric components (aka breadboard).
- Two transistors BC547 B
- 1 resistor 100 kOhm
- Solid kern jumperwire to connect the components on the plugin board
(I bought an electronics "experimenting package" for €10 / $12 which contained everything I needed at Conrad.)
- Two 10mm blue LED's
- More solid wire connectors.
Tools you need:
- Pliers to cut and bend the electrical wire
- a stripper
- Small screwdriver
- sharp knive
- scissors
- multimeter
- powerdrill (for twisting wires: see this smart instructable)
Step 2: Part 1 - Feet and Legs
Also see the pictures for building instructions and comments.
Blinky's feet are pretty straightforward to make. For a very easy way to twist the electrical cords, have a look at the instructable "a Perfect Twist".
The white powercord connectors are connected with small pieces of wire.
My Blinky is a bipod. His two legs make him wiggle a bit when he's stroked and tickled. But there's no law that says Blinky's must have two legs...
This step takes about 10 minutes, I guess...
Step 3: Part 2 - Body and Legs
Blinky's body consists of three main parts:
- A belly of white powercord connectors
- A helix-shaped twisted powercord. Gives volume to the body, one ending becomes a tail.
- The space inside the helix is used to store the battery.
- Two stripped and curved wires. These act as connectors, to close the electrical circuit that makes Blinky's LED-eyes shine.
Again, you are completely free in choosing the shape of Blinky's body.
This step will take 20-30 minutes.
Step 4: Part 3 - Blinky's Head
Building Blinky's head will take the most of the time. It took me about an hour.
Except for the blue leds, all parts came from the "learning package" bought at Conrad. If you're not familiar with electronics, I highly recommend that you buy a kit like the one I got. Everything you need is in there, even a lay-out of the circuit!
The +side of my 10mm LED's was not marked. I used a 4,5 V battery as a LED-tester and marked the plus-side of the LED's, before mounting them into the connectors. The plus-side of most 10mm leds are marked by the length of the leads, however: The plus-lead is a bit longer than the minus-lead.
This electric circuit serves it's purpose, but of course there are many more possibilities. Feel free to add extra features to Blinky's behaviour... In the end, we might be able to collect enough different kinds of creatures to write another eBook "On the origin of Blinkies".
Step 5: Finish Up - a Furry Coat for Blinky
If you like, you can give Blinky a coat! Make him as pretty and comfy (or scary, punky or cute) as you want.
I decided to give Blinky a furry skin. I used a piece of pluche from an old cushion, but anything else will do, of course. The double-sided foam tape is indispensable, once again.
Well now, that's all there is... You're done, and Blinky has a soulmate now. Don't forget to make an Instructable of it. Or post a pic in the comments. Thanks for reading!
Runner Up in the
LED Contest
31 Comments
5 years ago
I'm working on a science project that uses this type of science for SARSEF. my name is Matthew and I would like to interview you for the science fair project. tell me what's your full name, and where you are so I can tell you when to come over to my house at 2538 N fourgues avenue apartment A tuscon, arizona, 85716. my phone number is 520-322-9657. my mothers phone number is 520-808-2113. comment ASAP. it happens March 16th.
7 years ago
Can you explain a little bit about your circuit
8 years ago on Introduction
is there by chance another name the "white power cord connectors" go by, because I can't seem to find them anywhere in America. I was planning on making this awesome project! :3
Amazon sells these: http://amzn.com/B00KHSQ8CO
Thank you so much, this was very helpful! I can't wait to start on this project! :)
Please hit the "I Made it!" button when you're done :-) Have fun!
Try a search for "16 amp connector block" or "16 amp terminal block"...
May I humbly suggest a current limiting resistor in series with the LED's? You might hug her poor eyes to death. A 47 ohm would limit the If to roughly 40mA.
So, I really want to make this but I'm not very skilled. It's very complicated for me for I've never made a robot in my life! I am going to do this once I start making easier robots. I'll make sure to tell my friends about this!!!
Hey lwelton8! Thanks for your comment. Starting something is never easy, but Blinky is really a good project to start with. The electronics may look a bit difficult, but it's really not. A starter kit like this one (http://www.vellemanusa.com/products/view/?id=52573... has all the parts you need. Just get started :-). Drop me a line if you run into problems while building. Cheers,
Ynze
Reply 8 years ago
It looks like that link isn't working, so you know the name of the kit or another link to it? I really would love to build Blinky
Thanks for mentioning! Here's the updated link:
https://www.conrad.nl/nl/conrad-basic-elektronik-leerpakket-3964-leeftijdsklasse-vanaf-14-jaar-192296.html?sc.ref=Category%20Overview
love it! can you make a pray mantis next?
10 years ago on Introduction
This is great!! Exept, it kinda disturbs me....lol
Thanks :-) blinky has been for around in my house for over two years now, and he (she??) is as adorable as ever. Her favorite spot is the windowsill, watching kids passing by on the sidewalk...
12 years ago on Introduction
great, my dog thought he had a weird name, what was it? Blinky! hes not alone anymore, I bet he'll never notice this Blinky is not from flesh and bones
that is the single most epic thing ice ever seen
Reply 12 years ago on Introduction
:-D Thnx!
12 years ago on Step 5
oh! thank you very much for this led pet... i love blinky.....
