Introduction: Blob Puzzle (Puzzle Speed Challenge)
This project was made in Fusion 360. The goal of this puzzle is to fit all the pieces into the frame. the files will be available below. This puzzle looks simple, but is actually very hard.
Blob puzzle_Blob puzzle v1_Body1_Blob puzzle v1.stl
Blob puzzle_Blob puzzle v1_Body2_Blob puzzle v1.stl
Blob puzzle_Blob puzzle v1_Body3_Blob puzzle v1.stl
Blob puzzle_Blob puzzle v1_Body4_Blob puzzle v1.stl
Blob puzzle_Blob puzzle v1_Body5_Blob puzzle v1.stl
Blob puzzle_Blob puzzle v1_Body6_Blob puzzle v1.stl
Blob puzzle_Blob puzzle v1_Body7_Blob puzzle v1.stl
Blob puzzle_Blob puzzle v1_Body8_Blob puzzle v1.stl
Blob puzzle_Blob puzzle v1_Body9_Blob puzzle v1.stl
Blob puzzle_Blob puzzle v1_Body10_Blob puzzle v1.stl
Blob puzzle_ frame.stl
A 3d printer
Filement
Step 1: Step 1: Create the Frame.
This step is fairly simple. Create a center point rectangle, then create another rectangle inside that.
Step 2: Step 2: Create the "Blobs"
This step is a bit more complicated. Draw shapes inside the frame using the spline tool and the line tool. These should be able to fit snugly into the frame.
Step 3: Step 3: Extrude
Using the extrude tool, extrude all the pieces upwards. Extrude the frame upwards, and extrude the bottom downwards. You are finished with the model.
Step 4: Step 4: Print (optional)
Save the files as one file per body. Separate the pieces, and print. You are done!
Step 5: (Solution)
Above is the solution to this puzzle when fully printed and assembled.
