Introduction: Blockly RC Car for Programming
In this Instructable I will add Google Blockly programming functionality to RC 8 wheels stunt car that I gave to my son at Birthday.
I started to write the instruction after I finished the project, so the initial disassembled RC controller' photos already include final electronics.
These are the list of materials that are needed to make this project:
- RC car - 1 piece, but it won't be changed
- RC controller - 1 piece
- ESP32 Lolin S2 Mini - 1 piece
- resistors 500 - 2000 Om, 1kOm is fine - 6 pieces
- optocoupler PC817 - 6 pieces
- Boost converter Li-ion 3.7V to 5V - 1 piece
- Button with fixation - 1 piece
- Wire 0.2 mm, about 2.5 meters
- 18650 accumulator - 1 piece
- Case for 18650 accumulator - 1 piece
Step 1: RC Disassembling
Unscrew the bolts and open the cover
Step 2: RC Soldering Electronics
I found six buttons and it's soldered points.
Then:
- I cutted and tinned 6 * 4 = 24 pieces of 0.2mm thickess wires with length dependant on length from button soldered points to Lilo S2 Mini pins, from 5 cm up to 10 cm.
- Soldered resistor to input PIN 1 of each optocouple, and all wires to each optocouple
- I did not solder resistor to output PINs 3 or 4 of optocouple, beause RC controller already limit current, otherwise pressed buttons would fry RC controller.
Step 3: RC Soldering Power
I attached 18650 case and passed power wires through the holes and twisted around inner plastic guides for fixation and glued by hot glue.
Then:
- I glued power button to place of fake antenna.
- I soldered boost converter to button and to ESP32 VBUS/GND pins
Step 4: Arduino IDE Preparation
Clone sources https://github.com/vadimostanin/BlocklyRCCar
Steps for preparing Arduino IDE:
- Install Arduino IDE 2.3.X
- Install ESP board:
- "esp32" by Espressif Systems, version 3.0.0
3.0.0 works fine, but 3.1.0-3.3.0 have DHCP issue with assigning IP to WiFi client while connecting.
But maybe it's just my code issue.
- Install Arduino libraries:
- "ESP Async WebServer" by EP32Async, version 3.8.0
- ArduinoJson" by Benoit Blanchon, version 7.4.2
- Install tool for uploading HTML file to LittleFS/SPIFFS memory:
- According to the instruction https://randomnerdtutorials.com/arduino-ide-2-install-esp32-littlefs/:
Copy https://github.com/earlephilhower/arduino-littlefs-upload/releases/download/1.5.4/arduino-littlefs-upload-1.5.4.vsix or other newest to folder "<Windows_User>\.arduinoIDE\plugins\" and restart Arduino IDE 2.3.X
Step 5: Flashing Firmware
- Plug-in Lolin S2 mini to PC USB port
- If Lolin S2 mini is not recognizable, then at the board press-hold "0" button, then press-release "RST" button, then release "0" button
- Select port
- Pressing "Upload" button will compile and upload firmware
Step 6: Uploading HTML
- Check that file "arduino-littlefs-upload-1.5.4.vsix" is present at folder "<Windows_User>\.arduinoIDE\plugins\" and Arduino IDE 2.3.X was restarted after copying, as specified at "Step 4: Arduino IDE preparation"
- Close "Serial monitor" as it will interfere process.
- Check Port, it should be the same value as during flashing.
- Press "Ctrl+Shift+P", and type "Upload LittleFS", press Enter
Process will fail and will switch port to another, select new port value and try again, now process should success.
Step 7: Testing
- Insert 18650 to battery case
- Turn-on CAR
- Turn-on power button for ESP
- Connect Tablet or smartphone to WiFi AP "ESP32_Robot"
- Open web browser to URL "httpt://192.168.4.1", wait and reload page 1-2 times, it can lag due to HTML size.
- Make program and press "Send to ESP32"
Expected behaviour is that the car should move and follow the program.
Feel free to extend project.
