Introduction: Blue Screen of Death Batch
Make the blue screen of death a shortcut on desktop and disguise it or make it a screen saver.
Step 1: Make the Batch File
I made a batch file to imitate the blue screen, just copy and paste this to notepad and save it as bluescreen.bat
@echo offcd /clscolor 17echo A problem has been detected and Windows has been shut down to prevent damageecho to your computer.echo.echo The problem seems to be caused by the following file: SPCMDCON.SYSecho.echo PAGE_FAULT_IN_NONPAGED_AREAecho.echo If this is the first time you've seen this stop error screen,echo restart your computer. If this screen appears again, followecho these steps:echo.echo Check to make sure any new hardware or software is properly installed.echo If this is a new installation, ask your hardware or software manufacturerecho for any Windows updates you might need.echo.echo If problems continue, disable or remove any newly installed hardwareecho or software. Disable BIOS memory options such as caching or shadowing.echo If you need to use Safe Mode to remove or disable components, restartecho your computer, press F8 to select Advanced Startup Options, and thenecho select Safe Mode.echo.echo Technical information:echo.echo *** STOP: 0x00000050 (0xFD3094C2,0x00000001,0xFBFE7617,0x00000000)echo.echo.echo *** SPCMDCON.SYS - Address FBFE7617 base at FBFE5000, DateStamp 3d6dd67cpause >nulclsecho Downloading viruses . . .ping localhost -n 5 >nuldir /spause >nul
Step 2: Send to Desktop
Find it in all files by going to notepad > file > open > change Text Documents(*.txt) to All Files > find bluescreen.bat and right click it > send to > desktop (create shortcut).
Step 3: Disguise It
Right click the bluescreen shortcut icon on your desktop and rename it to Internet Explorer > exit > right click it again > properties > change icon > change it to the internet icon > apply > exit. Now it should look like Internet Explorer but when someone clicks on it, the blue screen of death should popup.
Step 4: Make It Run Full Screen
Right click on the disguised bluescreen shortcut we made > properties > layout > add a 0 to the width and the height under Windows Size > apply > goto the Font tab > make the font the biggest > apply > exit.
Step 5: Make It Your Screen Saver
open the disguised bluescreen shortcut and it will run full screen, now while it's opened press 'Print Screen' on your keyboard. exit. Go to paint (start>all programs>accessories>paint) > edit > paste > and save it as bluescreen. go to picture gallery make a new folder > place the bluescreen picture in your folder > exit > go to control panel > appearance and personalization > change screen saver > make the screen saver run from windows photo gallery > settings > browse for the folder you placed only the bluescreen in and open.
