Introduction: Bluetooth-Controlled Follow Me Robot With Ultrasonic Sensor and Mecanum Wheels
4-Mecanum Wheel robotic vehicle controlled via Bluetooth that can follow an object using an ultrasonic sensor. Additionally, the robot uses a servo motor to scan its surroundings for objects and adapt its movement accordingly.
1 × Arduino Mega
4 × DC Motors (with Mecanum wheels)
1 × Adafruit Motor Shield
1 × Ultrasonic Sensor (HC-SR04)
1 × Servo Motor
1 × Bluetooth Module (e.g., HC-05)
1 × Battery Pack
1 × Robot chassis with wheel mounts
Screws, nuts, and bolts for assembly
Soldering kit
Screwdrivers
Jumper wires
Hot glue gun or double-sided tape
Step 1: Assemble the Chasis
Attach the wheels to the motor mounts on the chassis.
Secure the DC motors to the chassis using screws.
Mount the servo motor at the front of the chassis using hot glue or screws.
Step 2: Wire the Electronics
You can use the pins that you want to use and feel more comfortable according to your project. Here are the connections of our project:
Motor Connections:
Connect the 4 DC motors to the motor shield’s output pins (labeled M1–M4).
Ultrasonic Sensor Connections:
Trig pin → Arduino digital pin 15
Echo pin → Arduino digital pin 14
VCC → 5V
GND → Ground
Servo Connections:
Signal wire → Arduino pin A9
VCC → 5V
GND → Ground
Bluetooth Module Connections:
TX → Arduino RX1
RX → Arduino TX1
VCC → 5V
GND → Ground
Power:
Connect the battery pack to the motor shield’s power input. Ensure the voltage matches your motor specifications.
Step 3: Coding
If you want the servo to scan slowly, pause at edges, and react to detected objects, modify the followMe() function:
cpp
Copy code
void followMe() {
// Sweep and pause logic
for (servoAngle = 10; servoAngle <= 70; servoAngle += 5) {
scanningServo.write(servoAngle);
delay(100); // Slow down servo movement
long distance = measureDistance();
if (servoAngle == 10 || servoAngle == 70) {
delay(500); // Pause longer at the edges
if (distance > 0 && distance < 400) { // Object detected
Serial.print("Object detected at angle: ");
Serial.println(servoAngle);
scanningServo.write(servoAngle); // Point servo at the object
break; // Exit scanning
Step 4: Pair the Bluetooth Module
Power up the robot.
Use your smartphone to pair with the Bluetooth module (e.g., "HC-05").
Install a Bluetooth terminal app to send commands that you have written to Arduino:
'W' → Forward
'S' → Backward
'A' → Left Crab
'D' → Right Crab
'Q' → Front-Left
'E' → Front-Right
'C' → Back-Right
'Z' → Back-Left
'R' → Turn Right
'T' → Turn Left
'X' → Stop
'F' → Follow-Me mode
Step 5: Testing
You are done with the Mecanum Robot. Now you can test it.
Place the robot on a flat surface.
Enable Bluetooth mode to control it via your phone.
Test the follow-me functionality by holding an object (your hand, for instance) in front of the ultrasonic sensor.
