Introduction: Boat Shelf
This is a remix instructable. It is based on my instructable A boat from a single 2x4
If you saw my boat, then you know it was covered with a ugly plastic bag.
As a boat it was not really good but I like the construction therefore I decided to make a shelf for my towels.
Step 1: Built a Boat From a 2x4
please watch the video or have a look to my instructable
Step 2: Remove the Cover and the Seat
The cover was fixed with Duck-tape and it was not difficult to remove it. But it was a lot of work to clean all the glue rests with alcohol. I also removed the seat just with a hammer.
Step 3: Adding Feet
The feet are only three wooden blocks I screwed on.
Step 4: Adding Cross Bars
I placed a piece of wood above one section and made a line with a pencil. Then I cut it with a jigsaw
Step 5: Correcting Mistakes
Then I realized I cut it on the wrong side of the line. Therefore I added a little piece of wood to close the gap
Step 6: Adding a Middle Bar
The middle bar has a dado on one side. First I made this dado then I put the bar into the place. At this moment it was longer then necessary and it was easy to made a line on the front bar. Then I cut it, put it in place with wood glue and drilled a hole for a wooden dowel.
Step 7: Adding All the Other Pieces
This was the same procedure for every other piece. Put it in place under the existing construction, make a line,
cut it and glue it in place.
Step 8: The Result
I sanded it and added some layer of linseed oil.
It is not very strong but it is enough for towels.
If you like it, I am glad if you vote for it in the Shelving Contest 2016!
If you want to see more of my work, subscribe to my Youtube-channel
